1/35 Great Wall Hobby 12. 8 cm Pak 44 .
Afternoon.
Got on quite well today, only one part, well there are two intotal caused a few problems, mainly because the drawing wasn't to clear to me. They appear ok though as long as you don't look to keenly.
May looks all very apparent to some, but with the sizes I can barely see any detail as in C23, that reduced end is a nono.
By this time I must have stared at this drawing for what seems like hrs, so taking the glue I set too.
Seeing this in close up the left hand lever thing should have gone to the RH side of the part on the bar. The one on the right is the wrong way round ! no wonder it didn't fit . Oh well something to alter tomorrow:smiling3:
Decide to have the breach open as if they fired their last round and gave up.
C&C WELCOME.
Thanks for looking in.Comment
Thanks Andy.
You can say that again Paul. Spotted the first printing error earlier, two parts right and left miss numbered. Not long to go on this part now.
I made a slight c***-*p at the begining, reduced the night of the base legs, as if it was in transportation more. With a gentle sawing and some sprue think I can replace the gap and get it right.
Paint wise Yellow , but this gun has been in battle so lots of chips and grime.Rubble galore and derbris. Looking fwd to to dio part !Comment
Evening all.
Carried on with the gun assembly.
Some very thin section here but managed not to damage any.
Spot the error----------- yes two B 8's, Easy to see if you got mixed up, but proofreading would help.
I loved this piece, everything just fell into place, the smallest pins fitted, again the moulding is perfection, and it's not a new kit either.
All wheels on, since that photo was taken all the support flanges have been cut off, new replacement off cut of sprue Ca'd onto the flange. Hopefully they can go back on tomorrow.
C&C even abuse welcome.
Thanks Neil.
It's a beauty to build, some of the instructions to me seem a little misleading, although the drawings themselves are good , some of the arrows pointing to where the part to fit afe not clear. That could be down to me, some one else with more knowledge of the gun might well sail through.Comment
