20ton Bulk Grain Hopper Diorama..
  • Tarps
    • Sep 2020
    • 146
    This will be another micro diorama I plan to build with a railway theme. I like railway wagons so I plan to have a 20 ton bulk grain hopper standing at a factory siding.
    I will be building a low relief workshop building with wall as the backdrop. I will be adding a ground points lever as part of the diorama and weathered ballast to replicate oil, muck and grease.
    A few weeds and tufts of grass will be evident as they always get ahold somewhere.
    I have added a picture of my 4mm scale laser cut workshop building items.
  • Tarps
    • Sep 2020
    • 146
    Started work today building part of the 4mm scale laser cut workshop building.
ID:	1135111Click image for larger version
    • Tarps
      • Sep 2020
      • 146
      Hi today I have been working on building and painting up the low relief workshop. The roof still needs finishing off.
      • JR
        • May 2015
        • 18273
        There is nothing amiss on that brick work Kevin.
        What's that laser cut mdf or ply like to paint with acrylics, does the grain rise ?
        • Tarps
          • Sep 2020
          • 146
          Hi John thanks for your comments, you can use acrylic and oil paints on this and they seem to keep their shape really well. I prefer painting only with acrylics.
          • Tarps
            • Sep 2020
            • 146
            Hi I have been busy building a low relief store building for the diorama. Im pleased with the finished item.
            Once it’s on the plinth I can add some more weathering and weeds.
ID:	1136722Click image for larger version
            • Tarps
              • Sep 2020
              • 146
              Hi I have glued the low relief store building in place. I can now start concentrating on build brick wall to the right hand side as you look at it.
ID:	1136724Click image for larger version
