Tonight,Long stick goes Boom.
  • The Smythe Meister
    • Jan 2019
    • 6248
    #91
    Originally posted by papa 695
    Some great work from bits and bobs Andy.
    Thanks very much Ian,it`s quite theraputic in a taxing kinda way!!:smiling:
      • Jan 2019
      • 6248
      #92
      Originally posted by Mini Me
      Your head might hurt a little but look at what you have accomplished so far.........basically a lot from not much at all! Talk about unconventional modeling materials....this takes the cake. Nicely done. Rick H. :thumb2:
      HA! Cheers Rick,much appreciated,
      It`s quite rewarding using bits of "Leftovers" and finding unusual sources to hack about and make use of:thumb2: !
        • Jan 2019
        • 6248
        #93
        Originally posted by minitnkr
        Some excellent scratchery. I think you'll need to make a pair of wheels flexible or phony up some linkage hooked up to the hitch to pretend they are. PaulE
        Good point and well made mate! I may well have a go at that,although to be honest,i`ve come so far now it may be a little too awkard to make those changes:thinking:....... I`ll ponder that thought.
          • Jan 2019
          • 6248
          #94
          Hi Andy
          i think your paint issue is because the item is made of polythene, like the old airfix soldiers. The perceived wisdom on painting those these days is to first prime with Gesso or PVA glue. Apparently plasticote spray paint works as well.
          Thanks for that Tim..... a nice hint there:thumb2:! I actually have a few "Plasticote" rattle cans in the garage,i tried the White Primer,then went over it with OD and Hey Presto!!......... It worked a treat:hungry:,nice one mate!!
            • Jan 2019
            • 6248
            #95
            Originally posted by adt70hk
            Andy
            That is done seriously top notch scratchery. Very well done indeed!
            ATB
            Andrew,Thanks very much Sir!
            It`s blimmin` good fun!:thumb2:
            • scottie3158
              • 14221
              • Holbeach
              #96
              Andy,
              Great work and imagination to create a great build from bits and pieces.
                • 18932
                Glad that worked Andy, I’ve never tried it, just read it lots of times. I suppose the clue is in the name.....the item is plastic and you needed to coat it....hence plasticote....
                  • Jan 2019
                  • 6248
                  #98
                  Hello Chaps:hungry:,
                  A bit of an update,although i have to admit that the Searchlight itself is proving to be much more Taxing than the Trailer!
                  It`s taken a lot of hacking and bashing,(not to mention time!),to get not very far:dizzy:.I`ve decided against the tin foil as the reflector,and bought a £1 baking tray to cut one out...... it should provide a much smoother suface-well,that`s the plan anyway!!:thinking:
                  For those who have not seen what i`m trying to make,here`s one of my ref pics......
                  The difficulty that`s caused the delay is the "Wishbone" arm that the Tub itself sits in,(as Richard F pointed out early Doors),after much head scratching i thought of an electrical conduit terminal box,the diameter of which is just about perfect! so i cut it above the locating lugs.....
                  Then sliced it down to a width of 8mm........
                  ....... and finally,shaved off the Lugs to leave a "Pad to take the pivoting wire.........
                  That done i could attach it to the "Tub"...... the flexibility of it means i can just open it up a little and pop the pins into the small tubing recepticals that i glued into the tub side.........
                  The picture`s not great,but you get the idea! Next is to bulk up the bottom of the arm so i can then fix in the locating pin to place it onto the trailer...... still pondering that one!:rolling:
                  So that`s it so far,get that arm done and detailing the drum itself will be a doddle!:thumb2:
                  It will rotate,swing up,and of course light up,so up to now i`m fairly happy with it,although,of course,it`s not that accurate...... but the best i can do!
                  Thanks for looking in,and as always,any thoughts,hints,tips or plain old abuse is more than welcomed!!
                  Andy
                    • 18932
                    Looking good Andy.....
                    • Mini Me
                      • Jun 2018
                      • 10711
                      #100
                      That fits like a Glove!! Top work mate. Rick H. :thumb2:
                      • Neil Merryweather
                        • Dec 2018
                        • 5199
                        • London
                        #101
                        brilliant!
                        that's my kind of out-of-the-box thinking- love it!
                          • Jan 2019
                          • 6248
                          #102
                          Cheers Tim,
                          It`s getting there!
                            • Jan 2019
                            • 6248
                            #103
                            Thanks Rick,it took a while to come up with something the right diameter! :smiling:
                              • Jan 2019
                              • 6248
                              #104
                              brilliant!
                              Nice one Neil,and thanks very much..... i`m glad you`re enjoying it!:thumb2:
                              • scottie3158
                                • 14221
                                • Holbeach
                                #105
                                Brilliant scratchery.
