4mm scale micro diorama
  • Tarps
    • Sep 2020
    • 146
    Morning this diorama will have a railway theme to it as I just love railways.
    The diorama foot print is 150mm x 100mm. This diorama will be modelled around an Andrew Barclay loco I have recently purchased and will be Era3 which is 1923-1947.
    I have started work weathering up the track and using a white fry brush affect to capture the old timber.
    • 18901
    Looking interesting Tarps.
    • Tarps
      • Sep 2020
      • 146
      Hi progress on this little diorama is going nicely. The cobbled section of the diorama has been painted and weathered to capture the affect I wanted.
      The point has also been painted up and dry brushing white into the sleepers gives it the old wood effect. I'm pleased with how it's turning out.
      Or Fred the painter is busy erecting fence posts.
        • 18901
        Nice progress Tarps. Seems you have changed from a straight track to a turnout. Just out of interest, are you going to paint the check rails on the turnout? They would be the same colour as the track except they wouldnโ€™t be polished by running.
