Vignette 28 cm spzb41 AT gun and crew
  • Mini Me
    • Jun 2018
    • 10711
    #16
    Nice progress on this Joe.......interesting subject. Rick H.
    • Strenko J
      • May 2018
      • 752
      • Joe
      • Pittsburgh PA
      #17
      Originally posted by minitnkr
      Some pics I've used for ref. Ammo was scarce, but seems to have been mounted on almost anything. There are UTube videos too. PaulE
      [ATTACH=CONFIG]n1144518[/ATTACH] [ATTACH=CONFIG]n1144519[/ATTACH]
      [ATTACH=CONFIG]n1144520[/ATTACH]
      [ATTACH=CONFIG]n1144521[/ATTACH]
      Paul
      yes have seen these and used some for reference as well.. forgot about YouTube...will check that out thanks
      • rtfoe
        • 9086
        #18
        Joe, that's a mighty big pea shooter with bling. Not very often scene in war doc videos. Wondered if they were ever used in the Bocage ambushes by Fallschirmjagers units. I'm guessing you'll be posing your vignette in the Eastern front.
        • Strenko J
          • May 2018
          • 752
          • Joe
          • Pittsburgh PA
          #19
ID:	1144672Click image for larger version
ID:	1144673Click image for larger version
          some updates.. artillery all blinged up with PE..now on to the figgies..yes I think the Eastern front is the place for this one Richard.
          • rtfoe
            • 9086
            #20
            Hi Joe, looking at the gun, it reminds me of a Boys anti-tank gun or the Russian anti-tank guns but a larger calibre. Wondered how thick an amour platting it can penetrate. Could it stop a T-34 or at least a BT-1?
            • Mini Me
              • Jun 2018
              • 10711
              #21
              Looks good Joe.....hope the figs. go well for you. :thumb2: Rick H.
              • stillp
                • 8095
                • Pete
                • Rugby
                #22
                There's a table of the armour penetration her: https://en.wikipedia.org/wiki/2.8_cm_sPzB_41
                • minitnkr
                  Charter Rabble member
                  • 7542
                  • Dayton, OH USA
                  #23
                  60mm sloped at 30 degrees, so couldn't penetrate T34 turrets, but everywhere else at a few hundred yards. Shermans were safe from the front and not so much anywhere else. A good three man crew could get 30rnds/minute out unmolested. Didn't do much damage to the tank once inside but had to illicit some evacuations. PaulE
                  • Greg_147
                    • Feb 2014
                    • 345
                    #24
                    Interesting piece and it looks like an exceptionally fiddly kit. I bet the real thing was good fun to fire though!
                    • Strenko J
                      • May 2018
                      • 752
                      • Joe
                      • Pittsburgh PA
                      #25
                      Figgies underway
                      • Strenko J
                        • May 2018
                        • 752
                        • Joe
                        • Pittsburgh PA
                        #26
                        Update on the figures... tried something different this time using a wet palette. I think it help me blend the folds in the uniforms better this way.
ID:	1146134Click image for larger version
ID:	1146135Click image for larger version
ID:	1146136Click image for larger version
ID:	1146137Click image for larger version
                        • rtfoe
                          • 9086
                          #27
                          The wet palette works Joe...figs look great.
                          • minitnkr
                            • 7542
                            • Dayton, OH USA
                            #28
                            Excellent result Joe. PaulE
                            • JR
                              • May 2015
                              • 18273
                              #29
                              Impressive work on the faces esp Joe.
                              Like the quilted in the first photo. Well done.
                                • 18908
                                Excellent work on the figures Joe. A wet palette is definitely the way to go isn’t it!
