1/35 KV-2 BUNKER BUSTER BY TRUMPETER
  • wotan
    • May 2018
    • 1150
    #166
    I know this is a matter of taste and personal preference, however I have always used a Badger 100 series gravity feed airbrush. The biggest advantage is that it was designed for airbrushing cakes. So there.
    • JR
      • May 2015
      • 18273
      #167
      Thanks John, there are so many to choose from, its rather bewildering . How ever I've ordered a Iwata by Neo, cheap and cheerful, hopefully I will get on with this better.
      • minitnkr
        Charter Rabble member
        • 7540
        • Dayton, OH USA
        #168
        That was ballsy Tim.
        • JR
          • May 2015
          • 18273
          #169
          As you can see above in my reply to John, its now on order, hopefully it will be here tomorrow, with luck !
          Great service form Aircraftnet, they replied to my message with in the hr and were helpful in their reply to my questions.
          Lets hope that this is the start of better spray work.
          • GerryW
            • Feb 2021
            • 1757
            #170
            Nice to hear of a company that can be bothered to reply to a query quickly!
            • JR
              • May 2015
              • 18273
              #171
              It is Gerry, I've dealt with them a few times over the years, Martin is very knowledgeable and helpful.
              • JR
                • May 2015
                • 18273
                #172
                Having just had a full on hail storm for 10 mins I'll begin.
ID:	1148502Click image for larger version
                Liking the new ab, feel ok and nice to use. Having cleaned it well after the primer I had to use the optivisor to put the nozzle back on, its so small . Going have to be care full taking that out I can see, definitely will do it over a large white plastic lid. In putting the needle back in I now have to have a finger on the side of the entry point and line the needle up with that. Going to take a while to familiarise myself with this.
                The pressure was set for 20psi, the AK primer mixed at approx 34/40 % thinners. A very fine line was very easy to produce and the trigger is positive.
                Leaving overnight to dry fully, then a coat of chipping followed by the 4BO. Looking fwd to seeing how the new AK 3rd gen works in this ab.
                Thanks for looking in, comments welcome .
                Dzhon.
                • Mini Me
                  • Jun 2018
                  • 10711
                  #173
                  Looking at this in primer without the tracks on, just shouts "TOON TANK" ! :tongue-out3: :tongue-out2::tongue-out::thumb2: Good to hear you are getting along with your new AB.......hope it works out for you. I'm still using the same one I bought 40 plus years ago......cant seem to wear it out. Rick H.
                  • BattleshipBob
                    • 6793
                    • Bob
                    • Cardiff
                    #174
                    Hang on, send the AB back, its sprayed red not 4BO stuff!!
                    • GerryW
                      • Feb 2021
                      • 1757
                      #175
                      It's ok, need the red lead as a undercoat to stop the rust
                        • 15703
                        Hi John
                        Glad the new airbrush is working out well.
                        • Si Benson
                          • 3572
                          #177
                          I missed all the airbrush bother....what a pain!:confounded:
                          Glad you’ve got the new one under control so quickly and hope you can get your 3rd gen paints through nicely :thumb2:
                          • JR
                            • May 2015
                            • 18273
                            #178
                            Hi Rick, it does indeed, perhaps that's where they got the idea!
                            The turret looks far too big in hight. Certainly couldn't hide behind a low wall of hedge!
                            I'm of the opinion that had I been spraying Tamiya or some other none acrylic paint and I hadn't had a mix up with the tips etc none of this would have happened.
                            Hope your getting on with those new brushes ?
                            • adt70hk
                              • Sep 2019
                              • 10409
                              #179
                              [ATTACH=CONFIG]n1148502[/ATTACH][ATTACH=CONFIG]n1148501[/ATTACH]
                              [ATTACH=CONFIG]n1148503[/ATTACH]
                              [ATTACH=CONFIG]n1148504[/ATTACH]
                              Dzhon.
                              Glad to hear the new airbrush is working well. I have to use the optivisor too when putting mine on.... And I have varifocal lenses in my glasses already....:loudly-crying:.
                              Keep up the good work.
                              • JR
                                • May 2015
                                • 18273
                                #180
                                Greetings Bob aka Mr StuG . Fear not, that's only a primer, tomorrow hopefully the 4BO will flow !
                                Ha, Gerry.
                                I see I have two of you to contend with :smiling2:.
                                Originally posted by Jim R
                                Hi John
                                Thanks Jim, feel much better being able to put some paint on with out a right.
                                Hi Si thanks. Yes looking fwd to seeing tomorrow if it handles it well.
                                I'd sent you an Gmail with the Bunker video on, will have to check it went tomorrow.
