1/35 KV-2 BUNKER BUSTER BY TRUMPETER
  • JR
    • May 2015
    • 18273
    #421
    Originally posted by Graeme C.
    Looking really good John, the re-bar & damage is very realistic, nice to see you have your mojo back.
    Thanks Graeme, enjoyed do the rebar, certainly helps with the detail.
    • JR
      • May 2015
      • 18273
      #422
      Evening Bunker Buddies.
      Been messing around with colours on the trunks, lots of differing colours and shades shown on the web of Scots Pine trunks so here we are.
ID:	1153881Click image for larger version
ID:	1153883Click image for larger version
      Not the easiest things to photo , might be better when they are on the dio later with some foliage , but you can get an idea.
      Thanks for looking in, comments welcome.
      Dzhon.
      • GerryW
        • Feb 2021
        • 1757
        #423
        Looking good Mr Race :thumb2:
        • adt70hk
          • Sep 2019
          • 10400
          #424
          Coming on nicely John.
          Keep up the good work.
          • JR
            • May 2015
            • 18273
            #425
            Thanks Gerry, should get back to this once the other build is under way.
            Cheers Andrew, bench is a bit cluttered ( no change from normal ) but as I said to Gerry I should get back to this soon. Appreciate you both looking in.
            • JR
              • May 2015
              • 18273
              #426
              Back again with this as it became a shelf queen, but I don't like to have have finished builds on the display area.
              Of course I misplaced the latex for the Pine branches and after searching ( but not well enough ) ordered a new bottle only to find the first one ! At least its only 50ml .
              A few photos.
              Note the clear sprue safety storage !
              Branch in work .
              Selection of debris to use for the ground under the trees.
              As these are Scots Pine which is common in Finland I had to look for another way of making them. The Sea Grass trees wouldn't look right and nor Ferns . Mature pins have most of their growth towards the top and every one seems to differ as opposed to the firs using ferns.
              Taking florists paper covered thin wire I'm continuing to make more branches, twisting then painting in a coat of Latex, once thicker enough I paint.
              Once the diorama is complete I can add the snow.
              Yesterday I sanded a metal plate I have for modelling and removed a amount of rust, though I would try using it.Once brushed up I placed some on the KV1
ID:	1158708Click image for larger version
ID:	1158709Click image for larger version
              Just hope the hair spray for the snow doesn't blow it all away :smiling3:
ID:	1158703Click image for larger version
ID:	1158705Click image for larger version
              • adt70hk
                • Sep 2019
                • 10400
                #427
                Looking good John. Good to see this back on the bench.
                • minitnkr
                  Charter Rabble member
                  • 7520
                  • Dayton, OH USA
                  #428
                  Sum'pin on the clear sprue you don't want to lose?
                  • The Smythe Meister
                    • Jan 2019
                    • 6248
                    #429
                    Great to see this back on the go Mr.R. :thumb2:
                    It`s looking very nice indeed,i`m particularly liking the muddied snow,snow is something i`ve struggled with over time....... even with using the "Precision Snow" stuff!
                    Good watch this is mate ,
                    Andy
                    • Mini Me
                      • Jun 2018
                      • 10711
                      #430
                      Excellent JR.........you might fix that rust in place with a light low pressure dusting of thinned flat clear before the hairspray treatment. Just a thot Sir. Rick H.
                        • 15668
                        Hi John
                        I remember this well. Real rust :thumb2: . I look forward to the completed trees.
                        • Mark1
                          • Apr 2021
                          • 4156
                          #432
                          Glad your back on this, was looking forward to seeing your trees.
                          • JR
                            • May 2015
                            • 18273
                            #433
                            Thanks Andrew, just been doing the branches so nothing to really show.
                            Yes Paul, head light and rear light glasses.
                            Andy
                            Andy getting snow to look right is not easy, I've found that using Sculpamold being white you can do a wash over it. When the PIS is used it will cover most of it, just showing a a hint of muddy .
                            Yes, good idea Rick,thanks :thumb2: I had thought about using a pigment sealer, but don't want it too run. Might well try your idea, did it with the last build and it didn't 't blow off the debris dust.
                            Originally posted by Jim R
                            Hi John
                            Hi Jim a chance it might work, certainly look right to me. Just hoping my ideas for the greenery work .
                            Thanks Mark, should be good, the only worry is using Balsa dowel , as you can expect very prone to snapping esp when I drill into it.
                            Thanks for the comments.
                            • GerryW
                              • Feb 2021
                              • 1757
                              #434
                              Looking very realistic there now. :thumb2:
                              I've always looked at trees as being 'difficult' items to get 'right' - I find that with me, they come out all the wrong shape!
                              • JR
                                • May 2015
                                • 18273
                                #435
                                Have to agree with you Gerry, the masses of needles on a Scots Pine are a problem.Using some foliage dark enough should be ok. Normally I use Sea foam trees that I grow for Silver Birch , but these are so different .Managed to day to do another coat of latex on the wires, and drilled out another truck and painted it. Going to be at least 3 days before I can start to paint the branches as the latex seems to take ages to dry.
