With an upcoming BD for my girlfriend I thought I would do a bit of building.....
..a present - I recently read about what's called "Book Nooks" or "shelf Inserts" closed narrow dioramas - in its truest form the dimensions of a thick Hardback. fitting a normal bookshelf.
I bought some svg files as a kit had them laser cut in 3mm Birch plywood and the result will hopefully be a iconic scene from Narnia - The Lion The Witch and The Wardrobe looking through the closet into the snow covered landscape with the Lamppost at its centre.
Will be lit by micro LEDs (white and blue) and the lamppost will have a flickering yellow LED.
Doors:
note the narrow shape:
lamppost:
micro leds
Doors after staining
more to follow....
Doors:
lamppost:
micro leds
more to follow....
