Meanwhile, somewhere in Europe
  • JR
    • May 2015
    • 18273
    #151
    That BW shot is great, seamless with the back ground Gerry .
    • GerryW
      • Feb 2021
      • 1757
      #152
      Originally posted by Mini Me
      That is amazing.........well done! Rick H.
      Originally posted by CarolsHusband
      Looks good Gerry.
      Thanks all, still a long way to go (and the possibility of making more mistakes) still tempted to pull that 'uphill' side apart and re-build that whole corner though. :thinking: It's about the only part that doesn't 'flow' into the photo.
      • adt70hk
        • Sep 2019
        • 10409
        #153
        Gerry
        Sorry got behind on this. That's coming on very nicely indeed. Well done.
        • GerryW
          • Feb 2021
          • 1757
          #154
          Originally posted by adt70hk
          Gerry
          Thanks Andrew, still a way to go, as I said, not sure what to do about that corner :thinking: do I pull it, or leave it - if I leave it, it's going to be in my face each time I look at it, to pull it, it's going to be a real pita (I know how much I glued it down!) but must admit that I'm really tempted to re-work it.
          • scottie3158
            • 14201
            • Holbeach
            #155
            Gerry,
            Very nicely done matches perfectly.
            • GerryW
              • Feb 2021
              • 1757
              #156
              Gerry,
              Yes - except for that one corner :tongue-out3:
              • GerryW
                • Feb 2021
                • 1757
                #157
                Decided that corner has to go - keep looking at it and it's laughing at me, so it's going - 'open dio surgery' taking place!:fearful:
                • GerryW
                  • Feb 2021
                  • 1757
                  #158
                  Corner having been worked on, and it's looking like I may be happier with it, though daylight will show up the mistakes!
                  • GerryW
                    • Feb 2021
                    • 1757
                    #159
                    Daylight arrives and shows up one or two bits needing attention:angry: but not too bad, considering that I was getting in my own light half the time I was working on it (won't fit on the bench) roadway is now wider - luckily I'd had to mask off the edge, so just removed the mask - slope is now consistent with the photo, and follows a natural line on the photo (seemed to be one all the way across, which is one reason that I put the landscape to the level it is).
                    Just need to get the last couple of areas done, and get the paint colours right.
                      • 15704
                      Hi Gerry
                      That looks excellent - well done.
                      • GerryW
                        • Feb 2021
                        • 1757
                        #161
                        Originally posted by Jim R
                        Hi Gerry
                        Thanks Jim, I'm still learning!
                        • GerryW
                          • Feb 2021
                          • 1757
                          #162
                          Been doing some more rocks, next point will be siting the schwimmwagens wheel points and 'levelling' so that there isn't a wheel in the air!
                          • minitnkr
                            Charter Rabble member
                            • 7540
                            • Dayton, OH USA
                            #163
                            Beautiful. PaulE
                            • GerryW
                              • Feb 2021
                              • 1757
                              #164
                              Originally posted by minitnkr
                              Beautiful. PaulE
                              Thanks Paul - I'd say that it's getting there, but still got some "new to me" things to do, which will take a while, and probably several attempts!
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #165
                                Nice! Rick H.
