Meanwhile, somewhere in Europe
Jim, I think that the reason that I'm 'going to town' is the quality of everyone elses work is pushing me to do more than I would if just doing it for myself!Comment
Question (brain has stepped up a gear - scary!) should I have a broken branch on the tree?
Reasoning
Now got firewood next to the fire, which would have to come from somewhere - my thoughts are probably not from the tree, as the tree would be 'green/live', and you need dead wood for a fire, but alternatively, could've been a 'windfall/gale damage' during the previous winter?Comment
Actually, think that I might just do the stump as an off-shoot :thinking:Comment
Surprising what you get up to when waiting for something that's 'holding the build up' - load of braided rope, pile of firewood, pot with steaming water, 'bushier' tree (with a dead branch broken off), the wet stream banks and the edges of the whole thing painted black - not much else I can get on with nowComment
Been putting the pin vice and drills to use - fairly sure that the pots/bucket are probably too thick, but as they'll not be 'in ya face' not too unhappy with the effort.
Drilled through the hand, bent half of the handle, then fed through and bent the other side, bucket handle and main pot handle are paperclip wire, the small 'loop' handle is a staple cut down and bent - the pots and bucket are cut from a 'intra-dental' brush cover heated and stretched over a pencil, base of bucket is from a yoghurt pot.
