Meanwhile, somewhere in Europe
  • GerryW
    • Feb 2021
    • 1757
    #106
    Originally posted by Mini Me
    That's the ticket Gerry.........just keep at it till you get the result you want :thumb2: Rick H.
    Think I'm getting there - the latest attempt looks 'reasonable' (to my eyes, anyway!)
    Tried the clingfilm 'trick' suggested by Richard, and worked onto the area, rather than onto a flat surface - will give it a chance to set, and I'll put up a photo for discussion later - fair enough, it's not equal to Rons (spanner570) work (doubt if I'll ever be able to equal his results!)
    • GerryW
      • Feb 2021
      • 1757
      #107
      Well, here's the results from the latest attempt, still sitting on the cling film - tried to lift it off, but it still needs to finish drying.
      Entry 'falls'
      Exit 'torrent'
      • Mini Me
        • Jun 2018
        • 10711
        #108
        That seems to be a promising result......have to wait and see how it works on the landscape. :thumb2: Rick H.
        • GerryW
          • Feb 2021
          • 1757
          #109
          reckon that the cling film will be able to be removed tomorrow (if it will come away, otherwise I'll trim it close as I can)
          • GerryW
            • Feb 2021
            • 1757
            #110
            Impatient as ever, trimmed off the cling film, put the pool base in, replaced the water and took a flash photo - not looking too shabby, if I say so myself (now edited, taken out the flash picture, and replaced with a couple of daylight ones)Click image for larger version
            • stillp
              • 8097
              • Pete
              • Rugby
              #111
              Looks darn good to me!
              • GerryW
                • Feb 2021
                • 1757
                #112
                Thanks Pete
                • rtfoe
                  • 9100
                  #113
                  Looks good Gerry, now if you haven't got any silicon underneath the cling film it will lift easily then because the silicon is transluscent you can paint the base underneath the silicon water with any hue to create depth and some rocks as the water cascades over them. Then place the cured silicon back this time with a little fresh silicon to hold it down. Weigh it down if you must by applying another layer of cling film and pour gravel over it. Let it setttle and remove the gravel and cling film after. You can use pins instead of the cling and gravel.
                  Good job. :thumb2:
                    • 15746
                    Hi Gerry
                    Fascinating. Looks as if all the work is paying off.
                    • GerryW
                      • Feb 2021
                      • 1757
                      #115
                      Thanks Richard, the two parts had to be cut out, so are just laid in place - the coloured part is just a photo of a (local) stream bed cut to size, which I was planning to use with varnish over the top (think that it'll stand up to the application of varnish, as it's a laser print, not inkjet), as it's about the right colour, (and I'm not sure if I'd be capable of getting the pool level/flat with silicon).
                      Must admit to 'reverting' to my original method with it, and sculpted with a nail (as per Rons method) with a dab of paint on the point, replenishing/cleaning as needed (often!), working in the direction of the 'flow', this seemed to give me a 'better' result than some of the earlier attempts, besides which, I could see what I was doing!
                      • GerryW
                        • Feb 2021
                        • 1757
                        #116
                        Originally posted by Jim R
                        Hi Gerry
                        Slowly getting there Jim, can't say how long it's going to take, as I'm learning as I go - at least the water looks as though I might be 'there' (until I spot something wrong!)
                        Thinking that I may well do an 'underlay', rather than painting the falls/run off :thinking:
                        Now edited with daylight photos
                        • Neil Merryweather
                          • Dec 2018
                          • 5199
                          • London
                          #117
                          It's looking very successful to me, Gerry.
                          • GerryW
                            • Feb 2021
                            • 1757
                            #118
                            Thanks Neil, it's the first 'big' one that I've tried, so learning a lot as I go - and having to dump/cut out the failures - perhaps I should have done smaller ones and joined them together :thinking: oh well, I'm going along ok as I am, so might as well carry on.
                            • GerryW
                              • Feb 2021
                              • 1757
                              #119
                              Burger, just noticed in the photos, there's a 'straight edge' and 'corners' to the pool - have to alter them before going onto the next phase.
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #120
                                That looks great Gerry, hope my first attempt comes close to yours. Rick H.
