SAA T-72A "Labna" ca 2014
  • adt70hk
    • Sep 2019
    • 10409
    #61
    Steven,.
    That is coming on beautifully.
    Very well done with the base.
    ATB
    • Mini Me
      • Jun 2018
      • 10711
      #62
      Wow Steven, the amount of detail you have on this is already over the top! Carry on and hope you are feeling better soon. :thumb2: Rick H.
        • 15702
        Hi Steven
        I'll add my WOW to Rick's WOW. Very neat and very skilled work. Amazing detail.
        • Steven
          • May 2018
          • 589
          #64
          Thanks Gents
          So I am working on the sidepannel the crews added - same principle as with the turret create some sort of pocket and fill it with tiles ,bricks etc. To offer stand off protection ( in theory).
          I am using Ammo's "U-rust "set and play around with acid, powders and portions to create purported "real" rust.
          I plan to add chipping to the panels - let's see how that goes
          • Steven
            • May 2018
            • 589
            #65
            Finally got to test fit the tracks
            Crew has added sandbags around areas where ERA are spread thin or missing altogether
            As can be seen head lights have suffered the wrath of rebel snipers similar fate has befallen the main IR searchlight
            • scottie3158
              • 14201
              • Holbeach
              #66
              Steven,
              great progress.
              • minitnkr
                Charter Rabble member
                • 7539
                • Dayton, OH USA
                #67
                Excellent update.
                • Steven
                  • May 2018
                  • 589
                  #68
                  Cheers mates
                  I am calling the weathering on the surfaces done save some dusting after mounting:
                    • 15702
                    Hi Steven
                    That rust stuff looks interesting. Looks to be very effective. The dio is coming on really well.
                    • Steven
                      • May 2018
                      • 589
                      #70
                      Holds alot of possibilities but is tempremental and using the reactors (small bottles) I found it difficult to gauge results as the result is not instant and it depends on amount: application etc
                      • Steve Brodie
                        • Sep 2014
                        • 4652
                        #71
                        that is going to be superb when all done
                        • Steven
                          • May 2018
                          • 589
                          #72
                          Thanks for the response
                          Concentrating on the empty space on the front sidewalk a considerable amount of time is spent trying to make everything look random white foam mark rubble piles the sidewalk will have a general covering of dust and rubble in most places
                          The empty 125mm crate ( rear) creates a tie in to the guys loading the beast chair and mattress connect the scene to a residential area and the small boxes and empty casings form debris of war
                          • Steven
                            • May 2018
                            • 589
                            #73
                            Finally got to the fun part: the weathering
                            Primed light gray followed by a coat of russian green, topcoat to protect it followed by chipping medium coat of Syrian sand followed by maltreatment by various instruments to produce this (right hand fender left untouched on pic to show the effect)
                            By Syrian standards on MBTs in urban conflicts this a somewhat conservative chipping. regardless, it can be overdone but feel I have reached a balanced result
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #74
                              She's looking good from this angle...... :thumb2:
                              • adt70hk
                                • Sep 2019
                                • 10409
                                #75
                                Ooooo now that is looking very indeed!!
                                Very well done.
