Malayan Emergency 1/35 scale.
  • JR
    • May 2015
    • 18273
    #151
    Funny how I find fire and water in modelling interesting :smiling3:
    You don't disappoint Richard, the last photos. Show real movement.
    The idea of using the packaging for the water poring over the rocksClick image for larger version
    Is perfect .That for me along with the vegetation in the water detailing the movement is perfection. Well done.
    • rtfoe
      • 9099
      #152
      Originally posted by Jim R
      Your clever water fall idea has worked well.
      Thanks Jim, I'm glad too that it worked being a first experiment.
      Originally posted by adt70hk
      That's coming on very nicely indeed.
      Very well done.
      Thanks Andrew, hope the rest goes nicely as well.
      The idea of using the packaging for the water poring over the rocks[ATTACH]433136[/ATTACH]
      Thanks John, the dry bed was a bit of a worry at the beginning. Even planning can get a bit shaky as assumptions can always backfire.
      Thanks for commenting guys. At the mo repairing the bridge as a cats foot just plowed through the planks.
      • Mini Me
        • Jun 2018
        • 10711
        #153
        Very interesting so far Richard. Looking forward to the next bit of progress. Rick H. :thumb2:
        • GerryW
          • Feb 2021
          • 1757
          #154
          Some great effects there, and the ideas behind them, certainly makes good reading!
          • rtfoe
            • 9099
            #155
            Thanks Rick, in a bit you'll see a bit. :smiling2:
            Thanks Gerry, glad you had a good read.
            Little progress but quite a lot for me as I had to go boldly where I've not been before and that is painting the whitecaps...literally trying to make it look natural. Anyway it still needs staining around the falls and gloss varnish to soften the effects...
            The effects of the gesso and white acrylic paints were stippled in... now there is movement.
            If I had known it was this see through I would have added fish.
            • rtfoe
              • 9099
              #156
              Hi, it's been a while since I touched on this dio. Nothing has changed except for repairing the bridge and searching for my stash of dried plants. I swore I had a 2'x2'x1' carton box that I lumped everything in.
              Found it and what a treasure trove. Didn't realise I had accumulated so much of it including some plastic plants from a flower accessory shop. The last time I opened this box was for my R&R dio. I picked out some relevant pieces here...
              ...and will spray them with an undercoat of black. Tropical lighting is very harsh and contrasting so any areas under the shade will look black. The plastic plants are ideal for undergrowth and tall grasses.
              Crafting the jungle will take a while...just like resin pouring. :smiling2:
              • rtfoe
                • 9099
                #157
                Having done the water and more detailing to be added later, I have cling wrapped it to work on the jungle. Funny thing is whenever I think of the word jungle CCR's Run Through The Jungle keeps playing in my head.
                The cover was necessary because I will be using a lot of can spraying which covers a lot of ground, then I detail with the airbrush and finally hand paint the highlights.
ID:	1160387Click image for larger version
                Okay the next few pictures will look pretty odd but it's the start of the main tree trunk that overhangs the stream. Now it's looking like a hang man's tree but there's lots more to add on with more vines, moss, branches, leaves, parasitic plants and roots.
                This is just one vine. There will be plenty more...
                The roots are being attached...the ends will be covered later.
                This part of the process always looks like a mess and heading nowhere but the picture will soon form. I hate this part of the process where I always have to think ahead and paint a picture in my mind and everything is new and experimented like that added branch below. The trunk is not stuck on yet to be removed for detailing.
                Already placing a sponge moss on the slope looks promising but no pics of it yet. If it gets boring, come back a few pages later to see if I got it right.
                • scottie3158
                  • 14220
                  • Holbeach
                  #158
                  Richard,
                  Your eye for detail and your skill in turning it into reality is superb.
                  • rtfoe
                    • 9099
                    #159
                    Richard,
                    Thanks Paul, keeping my fingers crossed as anything might happen or go wrong when experimenting.
                    • Graeme C.
                      • 1611
                      • Graeme
                      • UK
                      #160
                      Interesting to see how you're doing the jungle Richard, keep up the good work.
                      • BigGreg
                        • 2182
                        #161
                        Wow the river and the jungle work looks superb
                          • 15737
                          Hi Richard
                          Very good and so interesting to follow your progress. Glad you found your box :hugging-face:
                            • 18931
                            Fantastic waterworks there Richard. I can see the tree working really well as well….
                            • rtfoe
                              • 9099
                              #164
                              Glad if it's interesting to you Graeme. Lots of old school technic will be poured into process that you may be familiar.
                              • rtfoe
                                • 9099
                                #165
                                Thanks Greg, I won't be following your leaf by leaf method or I'll go crazy. :tears-of-joy: I'm going to cheat a little here and there but will still do singular leaf attachments to creepers and vines.
