Malayan Emergency 1/35 scale.
  • rtfoe
    • 9114
    #196
    Nice progress Richard. I’ve just had a catch up and am really impressed with the Bamboo especially. Wire wrapped trees will be good as well……
    Thanks Tim, like me I was also impressed with the bamboo outcome. TBH every step of a dio build is loaded with pressure to succeed...there's always the failures and only one final outcome.
    Originally posted by Jim R
    Hi Richard
    Wire branches are looking good. Is it copper wire? Easy to bend but stays in place :thumb2: interesting to see what you do next.
    Thanks, it's not copper Jim just normal stainless steel I think. Easy to bend as its thin. Fingers crossed.
    • rtfoe
      • 9114
      #197
      Hi Guys, I've finally planned how to cast my three Mk5 Enfields after successfully casting the Type92 Jap Heavy Mg. Here's the initial phase of the channeling vents... the barrel for the last one is a little bit wonky.
      After friend mentioned that bubbles may form at the barrel tips and sight, I added more channels and a well to hopefully help form the sight.
      It's in storage now waiting for the next process. Will experiment without the aid of plasticine to see if it works. The guns are light enough to float on the RTV I think.
      • rtfoe
        • 9114
        #198
        Hi Guys, there was a near disaster when I went too fast with the second pouring of the mould. I should have waited a little longer for the first half of the mould to cure properly or used mould release agent so there was a bit of tearing apart the two halves. What it did was make was undulating cuts that the two halves could fit like a glove I hope. Anyway here's fingers and toes crossed that it works.
        All the effort to add the key holes had gone to waste but hope with the tears there won't be any tears...oh the English language.
        Will keep you informed of the outcome good or bad.
          • 15798
          Hi Richard
          Looks fine. I'm sure it will work. I hope you remembered to put a thin film of white glue in the trigger area :thinking:
          • rtfoe
            • 9114
            #200
            Hi Richard
            Hi Jim, thanks for the confidence. Thin film not needed for this as the mould halves dissect half of the rifle but it complicates in the alignment which would create a step so I'm hoping that doesn't happen.
            So far it's better than expected and certain areas need to be thought off before the next casting. I removed the casting just before full curing so the fine parts aren't brittle to snap off. The fibres at the joint will easily be brushed off when hardened. The barrels are disappointing but correctable. The channel from the bottom of the barrel may need to be blocked as it makes an easy bi-pass and that's why the flash suppressor suffers from inadequate resin flow. I will try brushing in some resin in the next casting before closing the mould halves and before deciding to close the offending channel.
            This is how they look...out of the three one is good but the other two have barrel and sight problems.
            I will let it set before cleaning up and repairing the barrels.
            • Mini Me
              • Jun 2018
              • 10711
              #201
              Nice "gun collection" Richard! :thumb2: Rick H.
              • adt70hk
                • Sep 2019
                • 10438
                #202
                No complaints from me on this Richard....I wouldn't even know where to start on something like this.
                ATB.
                • BigGreg
                  • 2186
                  #203
                  I wish l could work resin like that....well done absolutely amaizing
                    • 15798
                    Hi Richard
                    Those look to have worked well.
                    • rtfoe
                      • 9114
                      #205
                      If it were only in 1:1 scale Rick.
                      ATB.
                      Andrew, my only complaint is if only I could see the outcome before the casting to know what to correct.
                      Thanks Greg, I think you can.
                      Hi Richard
                      Ah Jim, the second batch turned out better with just a bubble to fill in one of the butt stocks...much easier than the barrels.
                      • rtfoe
                        • 9114
                        #206
                        Hi guys, remember this? Well I have given it a dusting of PRU blue with the airbrush in a cloud pattern...
                        ...and painted the tyres in Nato black. The commercial masking tape over the windshield had been on for a number of years and left a hard crusty layer of glue which I removed with Mr Thinner as it doesn't attack plastic. That done I will remask with Tamiya tape and proceed with a layer of varnish before weathering. There won't be much as it has just been allocated to the unit and repainted...perhaps some mud and rain stains and olive drab bits showing through scuffing of edges.
                        At this time the Jungle Police contingent had their vehicles in a very dark blue and were remnants from Allied forces. The surprising thing is this is American and not British issue. Haven't referenced why we had this particular US equipment and I'm guessing its surplus left overs. Most pictures are in B/W so can't tell if they were in olive drab or dark blue. I'm sticking with dark blue.
                        I'm temporarily working on this while figuring out the ropes on the USS Constipation.
                        • rtfoe
                          • 9114
                          #207
                          Just showing the salvaged clear part of the windshield...
                          I polished it with Tamiya plastic polish compound that got rid of any residue left from Mr Thinner clean up.
                          • Graeme C.
                            • 1613
                            • Graeme
                            • UK
                            #208
                            Good to see you back at the bench with this one Richard.:thumb2:
                              • 15798
                              Hi Richard
                              I'd forgotten this. I like the idea of blue - makes it a bit different. Glad the windscreen cleaned up. Don't leave masking on for years :smiling: :rolling:
                              • scottie3158
                                • 14243
                                • Holbeach
                                #210
                                Richard,
                                Good to see you back again or have I just missed your posts.
