How many builds do you have on the go at the moment mate? Another great update and good luck with the figures
Malayan Emergency 1/35 scale.
RichardComment
Didn't have much bench time today and only did some positioning of the armatures and discovered making them with twisting two wires is better than the ones I have done up...
I found that drilling holes and gluing the wire arms wasn't holding and tended to turn where else the full wire makes sure it doesn't. All it needs is putty for the chest and pelvic region.
RichardComment
Just did the tree tops and laid on a first coat of base greens. At the moment the right side is a little heavy with the overhang and needs to be pulled back or trimmed.
Also its a bit too high in the middle which can be pulled and the wires cut shorter so that the left clump of leaves can connect to the left corner undergrowth. Must save space for the bamboo and banana trees. Will slowly pile things up and prune as I go like a mini bonzai.
RichardComment
Hi guys,
Thanks Jim, so far so good.
Thanks Scottie, it is evolving also and might get some alterations along the way. Seeing new angles I never thought of as it progresses.
RichardComment
