Malayan Emergency 1/35 scale.
  • rtfoe
    • 9092
    #346
    Erinmore - a real rave from the grave! And if I was to say 'pedantic' would that resonate :thinking:? I don't believe that a basic handle is beyond your skills!
    I believe the winding handle is already molded on the mag.:smiling2:
    Originally posted by JayCee
    Richard, this is looking very good. Just one small query if I may. Should the P.O.W. cans (flimsies) on the rear mudguards be removed ? I believe they went out of service quite early in WW2 and replaced by the ubiquitous 'Jerrycan'. If i'm waffling just tell me to mind my own business
    John.
    I thought about that too but pictures still show the flimsy cans still being used stacked in threes even and strapped down. I guess there was abundance of these left about.
    I've got to do some corrections to the cradle and brens...shortening the height so not exactly the Humber Scoutcar version. Found this out when figuring out the installation of the searchlight and reduce the guns to one as used by our armed forces.
    • JayCee
      • Aug 2019
      • 1133
      #347
      Cheers for the heads-up Richard. I honestly didn't know they were still being used so late. Never too old to learn something new :smiling:
      John.
      • Mini Me
        • Jun 2018
        • 10711
        #348
        Nice bit of welding there Richard. :thumb2:
        • rtfoe
          • 9092
          #349
          John.
          No probs John, I discover new things everytime like just now a picture comes up with a twin bren gun manned by local forces. So I will lower the guns and add the searchlight.
          It's a bit over exaggerated Rick but with paint on I hope it blends in.
          • Mini Me
            • Jun 2018
            • 10711
            #350
            I think you will be pleased with the end result......does not look over done from here. :nerd:
            • rtfoe
              • 9092
              #351
              Thanks Rick, your confidence in my finishing turned out right with paint on. The different plastics used must have made the jarring look. The even coat just blends and surprisingly I didn't prime at all and it shows with some scratches revealing plastic.
              • rtfoe
                • 9092
                #352
                For the searchlight I scrimmaged and found a suitable piece for the back portion...a 1/72 500 pound bomb...cut the tip off then stuck a 1/72 Panzer IV wheel on the front.
                This is the searchlight masked off with white glue over the lens for spray painting.
                I have lowered the guns by snipping off the supports and bending them to meet the pedestal points. Next is the base coat on with a lighter shade applied in a cloud pattern but mostly on the top panels.
                Guns painted...
                Sleepy time again.
                • Mark1
                  • Apr 2021
                  • 4156
                  #353
                  Thats looking good.
                  • Graeme C.
                    • 1605
                    • Graeme
                    • UK
                    #354
                    Looking good Richard, the gun mount & searchlight are nicely scratch built.
                    • Mini Me
                      • Jun 2018
                      • 10711
                      #355
                      Excellent!! :thumb2:
                      • rtfoe
                        • 9092
                        #356
                        Thank you Mark, Graeme and Rick.
                        After painting I discovered that the base plate had a weird double cut in notches so I sawed it...
                        • StephenN
                          • Jun 2022
                          • 135
                          #357
                          Richard, those pictures look amazing!! Very inspiring! Thank you for posting and keep going!
                          • rtfoe
                            • 9092
                            #358
                            Thanks Stephen, I'll try...it's a long way to go still.
                              • 15727
                              Impressive work Richard. Very enjoyable watching this come together.
                              • GerryW
                                • Feb 2021
                                • 1757
                                #360
                                Very fine work, your eyesight is far better than mine (even with the magnifiers) I'd be losing bits left, right and centre!
