Malayan Emergency 1/35 scale.
  • wotan
    • May 2018
    • 1150
    #121
    Richard, this is a very effective looking stream. When you come to add ripples you might want to try using an empty airbrush to blow ripples and waves into the medium, this method can create some very effective wave patterns.
    Best of luck
    • rtfoe
      • 9100
      #122
      Originally posted by Jim R
      Hi Richard
      That looks superb. The first pour must have done a perfect seal for the second. Looking forward to the next stages.
      Thanks Jim, sealed perfectly it did.
      Best of luck
      Thanks John B, I was thinking of using a straw and forgot about the airbrush...free air and less effort. Thanks for reminding me. There are areas I need building up of a wave pattern...should be interesting.
      I have taken off the gates and realised I over poured the end stage of the stream. I would have liked it shallower. I have also managed to remove the masks for the bridge legs. Some were easy but two needed a bit of digging. Dry fitted the bridge with some fettling and scraping.
      Sliced off the edge that curved up and will smoothen it and varnish before the ripples are put in.
      Needs a little tidying and repainting the black.
      The bridge didn't quite fit so might either carve the resin or the bridge legs itself to get it down.
      Little gaps where the resin meets the legs can be filled with more resin.
      I like this angle from the waterfall...
      Am quite pleased with my first clear resin water pour.
      • JR
        • May 2015
        • 18273
        #123
        Hat well and truly doffed Richard.
        A great result , those little touches that you made at the beging like the water falls have really worked now the resin has been added. As to the bridge not seating yet that's nothing really. Considering the effort you made with the dummy legs and then having to remove then from the dried resin , that in itself a challenge as the resin must have been drawn into the fibers.
        Most of us when trying water have have battled to have it flat with a few movement waves at the end .
        Very impressive indeed and realistic.
        • rtfoe
          • 9100
          #124
          Thank you John Patience,
          I'm having a ball with this resin thingy and the excavation of the mask was brutal and I didn't even wince cutting into the resin. Lucky thing I covered the dummy legs with cello-tape so that helped. Getting resin to flatten is easy as it reacts like water and the plane remains horizontal which ever way you tilt the base unlike silicone sealants thats extruded in those canisters from hardware shops that don't settle.
          The trick is to get it clear and then only work in the waves and ripples with other mediums like Hodge Podge, White Glue or even clear silicone paste if you can get past the smell.
          Still lots to do before I get the water looking the way I want. You'll see the difference once I'm done.
          • rtfoe
            • 9100
            #125
            Here's to show you the carving I had to do to get the legs to sit in snugly...
            Basically the angled beams were the problem so all four sides were carved and sliced with a sharp blade. The resin was easy to slice although it's hard to the touch.
            Sits in nicely now. I would have preferred the water falling further down but I haven't another layer on the base to work with.
            • JR
              • May 2015
              • 18273
              #126
              Very nice Richard, I had the impression the resin would be hard to cut in to.
              Nice addition with the leaves :thumb2:
                • 15746
                Hi Richard
                Looking very nice indeed. I am glad you were able to cut the holes for the bridge supports. The weeds etc do give a great impression of movement.
                • Graeme C.
                  • 1611
                  • Graeme
                  • UK
                  #128
                  Just had a catch up Richard, the resin pour has gone very nicely, the leaves on the waterfalls are a nice touch.
                  • rtfoe
                    • 9100
                    #129
                    Thanks John, me too until I got the blade onto it. Saw some pictures of leaves flowing over waterfalls and thought why not if it works.
                    Hi Richard
                    Thank you Jim, yup me too, I was apprehensive at first seeing how the resin clung to the masks. The ripples will show even more movement.
                    Yes, saw your catch up in the likes Graeme. Lucky first try with the pour and I saw that in a picture and thought I'd try it.
                    • rtfoe
                      • 9100
                      #130
                      Hi, my attempt using white glue didn't turn out as planned, it all went flat and the detail disappeared when it cured. Since I can't get any Hodge Podge from the art shop because of MCO restrictions I used Deluxe Making Waves. First making rough wave ridges emerging from under the bridge and later to try the straw blowing over it.
                      This is the first of the first wave ridges...
                      The waves are still setting and when that happens I will then add more of the paste and blow with the straw to blend it to the smoother areas. When that is done I will then paint in the crests with white and areas with turbulence. As it is it's starting to clear.
                      Meanwhile I found the Kamizukuri laser cut paper jungle leaves and shrubs I thought I had lost. These will line the banks and around the jungle.
                      It'll take a while to assemble the cut paper into the shrubs I need so come back later once done.
                        • 15746
                        Hi Richard
                        Sorry the PVA ripples didn't work although I suppose it could have been expected to likely flow out flat :rolling:
                        The Making Waves looks good. I've not come across those paper leaves/shrubs. I'll have to Google Kamizukuri.
                        • rtfoe
                          • 9100
                          #132
                          Hi Richard
                          Hi Jim, it was funny how I chased the glue all round the surface and it just settled down flat and the bottle says it's the new formula that doesn't run. :tears-of-joy:
                          Making wave I think behaves like Hodge Podge but it takes ages to cure and become clear. I will try the straw blowing and see if it works. Might even try mixing white glue with Making Waves and experiment. Look up Passion Models who carry the Kamizukuri product range. Or just google Kamizukuri.
                          • scottie3158
                            • 14221
                            • Holbeach
                            #133
                            Richard,
                            All looking very nice mate the stream is coming on well.
                            • rtfoe
                              • 9100
                              #134
                              Richard,
                              Thanks Scottie. Crafting the flow is quite difficult as I need to skillfully apply the paste in spots where the stream bed determines the crest of the waves like if there is a stone underneath then the water wave is higher as it flows over the stone. Slowly getting the hang of it. Good thing I can see the bottom.
                              • rtfoe
                                • 9100
                                #135
                                Hi,
                                I took time out from the water making to chill out with foliage making. Turns out it is as time consuming and nerve wracking to get it natural looking.
                                This is what's in the packing...lots of laser cut outs and very fiddly...
                                Previously I had pre-sprayed green on one of the sheets and have decided to do that after assembling perhaps to save paint with the spray concentrating on the close bunch.
                                On close up you can see that Kamizukuri even provide engraved detail on the leaves...another 20 or so bunches to go.
                                My tools to shape the leaves rather than leaving them flat and the sharp nose plier to twist the wire branches...
                                I'll save you the torture and show the finished set of leaves and bushes needed for the stream bank.
