HO scale city
    HO scale city
    Adding on to a previous diorama [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
    [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
            • 15673
            Hi Christopher
            That is very impressive work.
                [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
                  Still have a lot to add
                  • Mark1
                    • Apr 2021
                    • 4156
                    Very nice so far.
                    • minitnkr
                      Charter Rabble member
                      • 7528
                      • Dayton, OH USA
                      Just beautiful. Very evocative of the fifties.
                      • JR
                        • May 2015
                        • 18273
                        Just my thing Christopher.
                        Great painting , are they plaster kits , I can see the bases are scratched
                        Love to know more about the whole set up please.
                        • scottie3158
                          • 14201
                          • Holbeach
                          Christopher,
                          Excellent work on the buildings.
                            • 18895
                            Lovely brick and stone work Christopher. Coloration and texture is spot on.
                              Thank you for your comments. All of these kits are plaster. They are from Downtown Deco. I love these kits so much I have 30 more to build. I use a foam base. I use hydrocal plaster for the building foundations. I paint the base black then add AK asphalt to simulate the streets and parking lots. The sidewalks are also offered by Downtown Deco. All the plaster is sprayed using a white primer. As for the structures, I use water based paints bought at a local hobby store. The colors are watered down. Using a brush, I run the color over the castings until I get the desired look. I use three different colored paints on each building. I weather the buildings using either raw or burnt sienna. These buildings have not been weathered yet. I use my air brush for all the details on the structures as well as the doors and windows.
