Advance from Normandy.
  • minitnkr
    Charter Rabble member
    • 7529
    • Dayton, OH USA
    #31
    Great start Scottie. Worked slate tiles back in the 80s. Not fun.
    • tr1ckey66
      • Mar 2009
      • 3592
      #32
      Fabulous work Paul. Inspiring stuff
      Paul
      • yambam26
        • Mar 2011
        • 622
        #33
        Nice one Scottie, looks great so far!
        • scottie3158
          • 14201
          • Holbeach
          #34
          Originally posted by Laurie
          Well having a critical eye of 50 years in architecture you have done superbly well there
          Paul. Very nice piece of work on the dormer. A good idea of construction not easy.
          Perhaps a few broken tiles at the eaves. The slate edges are the most vulnerable there
          as the slate tops are nailed to the tile battens an upward blast will snap them.
          Very nicely done. Great to see DIY just love this work myself. Just thinking of a small hanger
          on my Jersey Airport. Look forward to your progress.
          Laurie, thanks for the great feed back I will stick some broken tiles on.
          Cheers Paul. I watched a program not that long ago of how the guys used to spend all day splitting the slate to make thousands of tiles a day.
          Paul
          Paul very kind of you thanks.
          Cheers Ben, good to see you looking in.
          • scottie3158
            • 14201
            • Holbeach
            #35
            Cheers Laurie if it passes your scrutiny then that's good enough for me.
            Originally posted by adt70hk
            Coming on very nicely indeed Paul.
            Keep up the good work.
            Cheers Andrew it's getting there slowly.
            Originally posted by boatman
            HI Paul this is lookin great carpentry an could you put your hand nr the build so i can see how big it is an whats wattle and dorb ?
            chris
            Will post a picture later. Tim has given an excellent description, which I will try and get right.
            Originally posted by wotan
            Paul
            Excellent building job to complement an excellent vehicle build. BTW it's Wattle and Daub" as in daub mud all over the woven sticks.
            Keep it coming
            Cheers John, good to see you.
            Different applications weren’t they though Laurie? I know you know this stuff Laurie, but others may be interested…..
            [ATTACH=CONFIG]n1160498[/ATTACH]
            Wattle, covered with mud/clay/dung/straw as a wall finish….
            [ATTACH=CONFIG]n1160501[/ATTACH]…and in use…..
            [ATTACH=CONFIG]n1160499[/ATTACH]
            Lath with the plaster removed…
            [ATTACH=CONFIG]n1160500[/ATTACH]
            Lath from behind, plaster keyed into the wall by the horizontal gaps.
            As I understand it, Wattle and Daub was used for main wall construction filling in between house framing.
            Lath and plaster was used for a smooth decorative wall finish inside a building? It is very difficult to hand things like radiators and cupboards on lath and plaster stud walls…believe me, I’ve tried LOL. The only way I found was to use spring toggle clips…..everything else just fell through or fell off…unless you were lucky enough to hit a stud behind the lath!
            Thanks mate for taking the time to post the pictures it will mean i will hopefully get it right.
            • scottie3158
              • 14201
              • Holbeach
              #36
              I have added some stonework to the building. The foam then received a coat of diluted PVA to seal the surface. All the sub assemblies have been undercoated with primer. They have just been put together loosely for the picture.
              The window details are a mixture of Mini art and scratched items. These will be painted and weathered before adding later. Not sure what colour to paint the building and woodwork so any suggestions will be considered.
              Finally a small section of wall for across the street.
              thanks for looking.
              Scottie
                • 18901
                Superb stuff Scottie. Really looks great. Excellent texture to the parts that will show well with paint.
                  Nice, takes certain mind to do these things.
                  All in the detail.
                  • scottie3158
                    • 14201
                    • Holbeach
                    #39
                    Thanks Tim very kind of you.
                    • scottie3158
                      • 14201
                      • Holbeach
                      #40
                      All in the detail.
                      Cheers Laurie, still details to add yet lights, guttering etc.
                      • boatman
                        • Nov 2018
                        • 14454
                        • christopher
                        • NORFOLK UK
                        #41
                        great work scottie these building dios really show out your skills at modeling very well done
                        chris
                        • JR
                          • May 2015
                          • 18273
                          #42
                          Hi Paul. thanks for the text.
                          Perfect in my eyes, Dormer looks right.
                          As far as the out side colour for the walls from a cream to light grey cement based render. Esp on that gate post with some brick work showing through.
                          Like the road way with the covered stone sets.
                          • minitnkr
                            • 7529
                            • Dayton, OH USA
                            #43
                            Most are outside the Crayola Eight so must defer to Dzohn on color.
                              • 15681
                              Hi Scottie
                              Looking great. The primer has really tied it all together. Gonna look great. I think John's colour ideas are spot on.
                              • scottie3158
                                • 14201
                                • Holbeach
                                #45
                                chris
                                Cheers Chris, very nice of you to say.
                                Cheers John I was thinking of a pale colour but wasn't sure what sort of traditional colours would have been used on the woodwork.
                                Paul that made me chuckle especially as they reckon soldiers eat crayons,
