Looks the Dog's JR.....keep it coming! :thumb2: Rick H.
T34/85 Tank in a village 1/35 Scale
You could try it and see I suppose :thumb2:Comment
Lots has been achieved my last post.
Base moulding with the Sculpy-Mould is done, need to be painted of course and some more detail done.
Meanwhile the buildings have had a first wash of a brown and black wash. I should have wiped the glue marks with some cellulose but haven't any left, so sanding is going to be the order of the day.
I've also finished the thatch, this is or wasn't done the way we think of as neat attractive finish. It was either made from straw sheaves or reed and just stacked on a timber frame work and pegged down. It was used in part of country where there was amply supply of straw and or reed and was used mainly for buildings for animals. The houses had timber roofs made from a water resistant timber, over lapped and pegged.
Still loads to do, but now the paint is starting to flow it should be more interesting.
[ATTACH=CONFIG]n1164581[/ATTACH]
[ATTACH=CONFIG]n1164584[/ATTACH][ATTACH=CONFIG]n1164585[/ATTACH][ATTACH=CONFIG]n1164586[/ATTACH][ATTACH=CONFIG]n1164587[/ATTACH][ATTACH=CONFIG]n1164588[/ATTACH][ATTACH=CONFIG]n1164589[/ATTACH]
[ATTACH=CONFIG]n1164591[/ATTACH]
Base.[ATTACH=CONFIG]n1164582[/ATTACH]
Steps cut into the bank.
[ATTACH=CONFIG]n1164590[/ATTACH]
Track marks.
Well that's it for now, hope you enjoy, comments welcome.
Dzhon.Lots has been achieved my last post.
Track marks.
Dzhon.Actually, when I saw this I thought it might come in handy if you ever wanted to try it on a future build.....no slight intended on your excellent efforts kind Sir.
Rick H.:thumb2:Comment
Sorry Brother, but your thatch roof is in need of a haircut.....Damn long hairs!!!............Other than that, most excellent work over all on this Dude 2. Up to your usual standards of finery..............................
Allen (still hanging in mid-air)Life's to short to be a sheep...Comment
Rick H.
Thanks Rick .
Hi JR, I had a chat with the local building inspector and he confided in me that your corner joins on the timber structure were, shall we say, "lacking".......he promptly pulled out his trusty "Rules" book and showed me a pic. of the proper "method" of joining timbers in the Eastern European vicinity and Russia (for ref only)....hope this is helpful :tongue-out3: :tongue-out2:Actually, when I saw this I thought it might come in handy if you ever wanted to try it on a future build.....no slight intended on your excellent efforts kind Sir.
Rick H.:thumb2:[ATTACH]440005[/ATTACH]
Here another example .
[ATTACH alt="download.jpeg"]440029[/ATTACH]
Thank Pete :thumb2:
[/QUOTE]
Dude 1 neither I or that roof need a hair cut ! :smiling: I don't have that much !
I thought it was ok , found these to base it on .
Shall have a look again at the straw roof in the morning and attack it !
Thanks for looking in .Comment
I've never tried warm water either with normal plaster or board adhesive Tim. I can't remember any other plaster becoming warm when mixed, other than coving adhesive. Dave might well be able to answer it better . The coving adhesive goes off very quickly, just with cold water .Comment
Tim.
On the next time I use the Sculpty mould I will check if it gets warm after mixing .
we will see later .Comment
Plumbers hemp used to be the recommended material for modelling thatched roofs….don’t know if you can still get itComment
