Normandy Bocage diorama
The 'pins' are fixed to the post in theory
This is the way i've made them so that i can actually fix them together.
So basically i have placed the female hinges (one with the hole) onto the gate but placed the male pin on top as if it's already sticking through it. This is so i can make the post hinge as a flat piece that the gate hinge can 'sit' on top of, thus making it look like a made up hinge.
Hope this helps clear it upComment
I wouldn't say 'in my element' as it is totally out of my comfort zone. But as you say. It's all about learning and experimenting. I've taken plenty of hints and advice from you guys on here so much of the thanks has to be directed towards those people including yourself.Comment
Just the top section of the tree to go. Never thought it would be such a slow process in putting the scatter (leaves) on. I suppose that now i've done one tree, i'll be quicker next time. But it's way more stressful than i thought it would be but i am trying to add the leaves in a methodical order so i'm not gluing over other sections where possible.
Just a few bits to clean up. The glue can be a little 'stringy' but at least it grips the scatter and holds it. Also had to re-attach a branch as i broke it off. rather a lot of swearing was done.
