Looking good Alan , like the trunks and the use of moss . I actually soaked some in the glycerine treatment once , not much difference to some I haven't and have kept for some years !
Normandy Bocage diorama
It's all good Al. Hope that you are not totally budgerigared by the snow storm and all are safe and warm.Comment
Well we lost power for 24 hrs and got our water supply back after 65 hrs. So we're getting there. Just glad i had the log burner to get some heat into the house. The farm was a scary place to be in the winds. Had a few flying pig huts too.Comment
Cheers Steven. Seen it around when i've been out for walks with my family and dogs and always wondered if it would be good to use when dry. So i took some and have put it on here to see if it works. Looks ok to me. Needs some flock added to it to make some leaves but i think it's passable.
The biggest challenge will be the trees.
I'd use sprinkled dried parsley for leaves.
RichardComment
Place steel wool (not the one with cleaner bits in it) into a spare pot (yogurt pots are ideal) and put in a measured amount of vinegar. Leave this to do its thing for at least 24 hours.
When ready add the same measured amount of water to the solution. So if you added 10 cap fulls of vinegar then add 10 cap fulls of water.
Use an old paint brush and brush the solution onto your bit of wood. It will turn from 'new' to grey. The longer you leave the solution the more it'll turn the wood grey.Comment
In the recesses of my memory, there's something about using grape 'tresses' for trees (what's left after eating the grapes) that was mentioned a while ago - I've a couple that are drying out, for when I'll need them, looking as though they'll need 'leaves' and possibly the parsley leaves sound like a plan!Comment
Well although i had trunks for the trees i've yet still to find the main branches for them. And those i have found need selecting carefully for sizes. So as a back up i picked some well dried broken branches i've had for a while. And if i am honest they already give the sort of look for the branches going over top of the road look, i want. They still need trimming to size in places but they are a good starting point.
I'll still need to add finer branches for the foliage and i'm thinking of going down the seafoam route for that.
