Normandy Bocage diorama
  • GerryW
    • Feb 2021
    • 1757
    #376
    Looking at this, makes me want to 'attack' my first attempt, which was sort of a similar scene (posted a photo of it in the 'critique' section when I first joined) and go 'all out' with what I've learned since.
    • AlanG
      • 6296
      #377
      Gerry. I would even do mine differently if i started again. It's a continuous learning process. But i'm getting there. Should really crack on with this one as well lol
      • AlanG
        • 6296
        #378
        Well slight accident with this 'stalled' build today. I took it off the SoD to do a little work on it as the foliage is coming off. I need to seal it onto the trees better.
        Whilst cleaning it up i dropped it. Not far granted but enough to break all the big trees off it. So i am going to have to recover this as much as i can. Still i suppose it gives me a chance to improve the ground cover before i fit the trees back onto it. Some of it has seriously faded so needs replacing. Still a little gutted though. Took so much time and effort to get this far with it.
ID:	1224877Click image for larger version
        • scottie3158
          • 14202
          • Holbeach
          #379
          Been there mate but as you say it's a chance to revisit.
          • A_J_Rimmer
            • May 2024
            • 801
            • Arnold
            • North Wales
            #380
            That's really annoying - I hope you can get it sorted!
            Arnold Judas Rimmer BSc SSc
            ''Happiness is a Triple Fried Egg Sandwich with Chilli Sauce and Chutney''
              • 18271
              Ouch. I bet that even Billy Connolly would have come second in the profanity contest that followed.
              I hope you take the challenge and get on it again.
              • AlanG
                • 6296
                #382
                I'm giving it a go guys. Typically there is not much left to do on it so hopefully i can get it finished soon. Then i can concentrate on building the vehicles and figures.
                And yes Ian. The swear jar had to be replaced with a swear bucket
                • minitnkr
                  Charter Rabble member
                  • 7542
                  • Dayton, OH USA
                  #383
                  Have heart Alan, it'll come together. When I screwed up the 10ton wrecker I had to relabel the wife's job barrel.
                  • AlanG
                    • 6296
                    #384
                    If i'm honest i nearly binned it. I was ready to take off the remaining bushes, trees and fence to reuse them on a new Bocage dio. Mostly because i've learned SO much making this dio from it's first concept to where it is now. I've done things in the wrong order and rushed ahead with some things rather than taking the time to get some basics right.
                    But i'm going to go with it for now. It'll still be decent enough to be a backdrop for some of the builds i have planned.
                      • 15707
                      Bet the air was blue. Definitely worth a deep breath and carry on. It was looking so good.
                      • AlanG
                        • 6296
                        #386
                        Did a little work on the faces today. Right side one still needs work. But i'm happy so far.
                        • rtfoe
                          • 9086
                          #387
                          Attaboy Alan, my philosophy is if it's broken just remind myself that when it first was in concept it was in pieces so I will repair it and correct the areas I had passed before.
                          Wabble
                            • 18908
                            Looking good Andy. Love the expression on the left hand guy….
                            • AlanG
                              • 6296
                              #389
                              Had a little spray bottle in the back of a draw and remember that it gave a fine mist when spraying. So thought that i would dilute some pva in warm water and see if i could mist the glue back onto the branches so i could reapply the leaves.
                              Seems to have worked a treat. Only tried it on a small section and will see if the leaves stick enough tomorrow when dried. But for now you can see that it has stuck the leaves at the bottom of the tree where as the top of the tree is still bare (ish) from where they fell off last time with the cheap glue.
                              If this way works i can see myself using it more often. For the sake of £1 it''s worth a bash.
ID:	1225171Click image for larger version
                              • adt70hk
                                • Sep 2019
                                • 10409
                                #390
                                Hi Al
                                Sorry to hear about the troubles with the base. Pleased to hear that you have not given up though.
                                The figures are very good . Particularly like the face on the 2nd one!
                                ATB
