29-31 Hampton Street. London's East End....Sept. 1940.
Your supposed to be resting the eye Chris . Have you managed to get any more pain killers yet ?
HI John i am resting it as ive got it closed while i read with my right eye an no no pain killers yet an wed goin to ask at docs if they can let me have a strip till my prescriptinons come through on friday if not then i'll have to go to chemist but cant at the moment as i dont want to drive even though my sight is now ok but hos said it would be a few days till i can drive so im bein safe till about friday or so to be on the safe side
Starting to add the roof spars.
The spars are balsa, cut down from 1/16" sheet stock. I cut down a coffee stirrer for the ridge board. Far stronger than balsa.
Gerry. I can't do the flashing until all the necessary elements are in place. Which, as I'm sure you have observed, they have yet to be fixed in place.
Thanks for the input chaps... :thumb2:
Roofing nearly completed.
Terraced houses didn't usually have fascia boards, but simply showed the ends of the roof spars. Had I adopted this option, I would have the extra work of sparring out the whole roof, the same as the outhouses, only to have them hidden! No thanks.
So, to be simpler and quicker, I fitted a length of fascia board to the bare spar ends. Over thick, I know, but it will either be destroyed or hidden by the undamaged sections of roof, so the 'Error' won't be seen.
Cheers.
Ron
Ron, I was joking - the level of detail that you're putting in here - what's the wall paper pattern going to be? :surprised: :tongue-out2:
