The plants look good John, well worth the effort.
Green House (Miniture ) Unknown scale by Robotime
Hi Graeme , thanks. Now trying to put the actual green house together. Clear plastic pre formed sheet , with end tabs that won't go through the slots in the opposing wall ! When they do as soon as you move it to attempt the other end, they all fly out !Comment
570 I could have done with the help of Matron , but think I have sorted the battle with the flexibility of the premade glazing sheet. Photos tomorrow of the state of play , the base now has its floor in along with the bottom timber sections, so it's more of a solid shape .Drying in between some steel sections to keep it in shape .Comment
Good evening to the gardening section of the forum, Percy here with an up date on to-days horticultural offerings.
Boy is this messy, every thing has to have glue on, paper and wire, more fun when you have to roll a section of green paper and put some flower heads in, once that is done then attempt to get it into a pot. Only to find the roll is not tight enough. Some of the papers have to be cut to 40mm long by 20 and with up to 5 wires in as well .Covered in glue trying to unstick fingers from leaves and the like, still its looking f[ATTACH=CONFIG]n1166877[/ATTACH][ATTACH=CONFIG]n1166878[/ATTACH][ATTACH=CONFIG]n1166879[/ATTACH]
Thanks for looking in, comments welcome.
Percy.
RichardComment
I may be wrong but I'm sure it wouldn't survive the winter temperatures.... We've had sub-zero overnight temperatures every night for about week now and we're only 50 miles north of London.
HTH.
AndrewComment
Ours is doing quite nicely in the window sill in the kitchen, although it's an indoor plant here in the UK and so for us snails is not an issue - at least in my experience.
HTH.
For Richard, seeing they hot temperatures and humidity perfect for your area.They originally come from West Africa.Common Names Snake plant, viper's bowstring hemp, Saint George's sword Scientific Name Sansevieria trifasciata Height Up to 40 inches Light Bright, indirect sunlight (some direct light is ok) Water Once a month; keep the soil dry Ideal Temperature 60° to 80°F (16° to 27°C) Prefers warm to hot temperatures Soil Free draining soil Fertilizer Doesn't require it. For fast growth, fertilize once in the spring and once in the summer. Pests Fungus gnats Toxicity Toxic to dogs and cats
Certainly not, siad it looked like a dead snakeComment
I was trying to ignore and wash my mind with soap and water when I saw Jim's comment...so wanted to reply. :tears-of-joy::tears-of-joy:
John, where can I find info like that in a whole list. Very helpful with irrigating and toxicity...I have 16 cats.
RichardComment
