Overwatch
  • Caustik Filth
    • Jan 2022
    • 364
    • Rob
    • Portsmouth
    Overwatch
    Hi folks
    After jumping in with no reconnaissance and finding the locals very hospitable ! I'm hoping for some tips.
    I hear that soil from the garden can be used in dios but should it be dried thoroughly? Would you go as far as putting it in the oven?
    Here's what I done so far, I had the idea for a dug out with a radio operator in it but realized it was way to close to a live firing anti tank gun so gone with a flanking fox hole instead.
    This may take a while but enjoying me self with a shant to get the cahoonaas to post it!
    Cheers Rob
    • 15783
    Hi Rob
    Looks like a nice plan for a dio. You can certainly use garden soil for a dio. I would spread it out on a tray in a low oven to dry it and kill any bugs.
    • minitnkr
      • 7564
      • Dayton, OH USA
      Very nice start. One tonner & 5cm is a great match. Trees providing some concealment for the track & providing a backdrop for the gun & MG is one idea. I dry & sift garden soil w/old cookie sheets & different size screens so soil, stones & larger rocks can be stored separately and applied as needed.
      • Caustik Filth
        • Jan 2022
        • 364
        • Rob
        • Portsmouth
        Ah ha, cheers Jim a job for mora before the roast goes in!
        Thanks.
        • Caustik Filth
          • Jan 2022
          • 364
          • Rob
          • Portsmouth
          Nice one cheers trees will be a challenge having not done them before, experiment fun to come!
          Thanks.
          • Airborne01
            • Mar 2021
            • 4024
            • Steve
            • Essex
            If you put it in the oven at 200 degrees for 30-40 minutes you can cook a plate of chips at the same time - just a thought!
            Steve :thinking:
            • Caustik Filth
              • Jan 2022
              • 364
              • Rob
              • Portsmouth
              Steve :thinking:
              Mmm, smoked earth flavour...
                I put mine in the microwave, potatoes are optional if you want .5 mins on full power !
                • minitnkr
                  • 7564
                  • Dayton, OH USA
                  Kind of like char broiled potato skins.
                  The backdrop of foliage allows the track, MG & Pak to blend into it w/o being profiled. A heavy ground cover, dead fall & undergrowth allows the trees to be less the focal point, thus being a little less of an issue.
                  • rtfoe
                    • 9114
                    I basically sift my soil or dirt and save the finer portions after chucking them in the microwave on high heat for a few minutes. Then use it as a mixture with spackle and white glue for texture spread. Then sprinkle over the still wet spread with a combination of various sized dirt and stones and static grass. When dry I add more static grass with white glue in planned places then paint. I seldom leave the terrain in its natural color.
                    • Caustik Filth
                      • Jan 2022
                      • 364
                      • Rob
                      • Portsmouth
                      Thank you guys for your tips and advice,. I think I might get away with using the microwave be too quick for the other arf to notice! Best be off to the garden for some supplies
                      Thanks again chaps.
                      • Caustik Filth
                        • Jan 2022
                        • 364
                        • Rob
                        • Portsmouth
                        Hi ya, I didn't get much bench time and was struggling to get my machine gunners to hold their gear properly so made a base and did a little here and there then realized putting them on the base would make painting everything a bit awkward . Doh ( learning curve ) so I'm hoping cling film keep them safe enuf...
                        I seen Night shift Martin black out his dio bases totally, would this be the best approach for a novice like myself ? or do different shades in different areas? If I'm gonna do it, it must be my next step!
                        Any advice would be greatly appreciated. Cheers Rob.Click image for larger version
ID:	1174589Click image for larger version
ID:	1174590Click image for larger version
ID:	1174591Click image for larger version
ID:	1174592Click image for larger version
                        • adt70hk
                          • Sep 2019
                          • 10435
                          Rob
                          Sorry completely missed this. That's coming on very nicely indeed.
                          As for Night Shift blacking everything out, the first time i saw him do it I thought what the.... Of course it works brilliantly but it's a big step to take if it goes wrong!
                          Keep up the great work.
                          • Airborne01
                            • Mar 2021
                            • 4024
                            • Steve
                            • Essex
                            May i suggest you take your (excellent) ideas on a small, sacrificial, and non-important unrelated piece; if it works, go with it - if not, play with the idea until you're satisfied then go for the 'Big One' - 'oorah ! (Then post the 'Masterpiece' to the envy of us lesser mortals!)
                              Rob .
                              Nothing amiss with the diorama , in fact the tree is suberb.
                              A black wash is best because you can always darken, rather than a full on black. I know because I've tried it ! :smiling3:
                              Keep it going .
