After seen this you will never see the AVRO CF-105 ARROW the same way !
  • JMARC
    • Sep 2008
    • 352
    HI GUY'S !
    Just like the title said ..I been working for a while on this project I have completed 89 AVRO CANADA projects so far and still a couple to do before I move on to another project ..So here below what on my work bench at the moment.. Remember all projects are done in 1/48 scale ..I work on this project on a weekly base so be ready for some update .. Note due of picture limitation I have created a page on google for each projects where you will be able to view where I'm at on each of them .So here they are
    # 1 AVRO DTV (Delta Test Véhicule )
    (MAY 06th) so far I have created the phase 1 and 2 DTV and rocket booster , I'm working on the launcher now
    If you like to view the complete WIP on this project , I have set-up an Google page for it ,on GOOGLE ,here the link:
    #2 1/10 AVRO ARROW FLUTTER test model
    (MAY 06th) So far the basic work on the model is done and I'm working on the decals and last details
    # 3 .....AVRO CF-105 ARROW MACH 2 WOODEN MUCK-UP
    (MAY 06th )So far it's almost done, what left are last details and scratch the nose radar , last work was retouching the nose paint and complete the main gear door and glued it into place
    # 4...ASSEMBLY JIG
    (MAY 06th).. the main JIG is completed, what I'm working on now is adding details and created the assembly buggies that hold the main parts , last work I done was creating a metal shelving unit and advance the middle fuselage section buggy
ID:	1175388Click image for larger version
    # 5 MASTER MOLDS
    (MAY 06th).. So far I have created pieces and prepare the presentation , at the moment I done the last work on the FUSELAGE TOP PLATING MOLD and created a working table that will be display shortly on the presentation base
ID:	1175391Click image for larger version
    # 6 OPEN / CLOSE CANOPY TEST JIG JIG
    (MAY 06th ) I'm almost true with the jig itself, the last work I done was creating the opening/closing mechanism
ID:	1175396Click image for larger version
    # 6 OURANDA IROQUOIS ENGINE
    (MAY 06th) So far the engine basic work is done, I'm now at detailing the mid section !
    # 7 AVRO CF-105 INFORMATION CENTER
    (MAY 06th) So far I have created several small section and I have yet to determine the size of the presentation I will need , the last wrok I done was the INTAKES and EXHAUST covers
ID:	1175394Click image for larger version
    # 8 ARRESTING HOOK proposition for ARROW MACH 2
    (MAY 06th) So far I'm almost true with the engine section that will hold the head of the hook and action mechanism
    # 9 FALCON MISSILE JIG proposition
    (MAY 06th) I have done the basic work on the jig last work was creating the legs to hold it
    #10 CF-15 ARROW TOW TRUCK
    (MAY 06) the main body is done on both version , the last work was on the front grill of the first version
    # 11 Jeep M.38 GÉNÉRATOR
    (MAY 06th) .Using the REVELL jeep , I made the necessary modification, I,m at completing the back doors
    # 12 WHITE 3000 gaz truck
    (MAY 06th) So far using the REVELL kit , I have modified the frame and Im on creating the back section
    #13 disassemble of the ARROW # RL-205
    (MAY 06th) The RL-205 is completed , the presentation base is prepared and I'm now creating all the wings disassemble parts
    Si vous désirez voir le montage intégrale visitez ce lien Google
    (MAI 06) Cette semaine j'ai pris une pause sur ce projet !
    Enjoy ..
    Jmarc
  • JMARC
    • Sep 2008
    • 352
    MAY 09th UPDATE !
    (MAY 09th ) Today I started the belly electronic access door !
ID:	1175506Click image for larger version
ID:	1175507Click image for larger version
    # 4...ASSEMBLY JIG
    (MAY 09th).. Today, I started to add detail to the metal shelving unit !
    # 5 MASTER MOLDS
    (MAY 09th).. Today I started a couple of maintenance pails !
