Late 1940's French Street Scene 1/35. Scratch built buildings, MB figures and Tamiya car .
Glad ya got cracking already John, standing room only by the looks....good on ya mate!
Cheers Rob.Comment
A constructive day, I'd already glued a section of cheaper foam board to the ply. Today was the start of the base itself.
Ok not everybody needs this, but as I love building and using foam board so much decided some time ago to invest. Such a clean cut and worth it.
Marking out for the Kappa line board to go on top , showing where the pavement is and the road.
Initial section of Kappa line board laid over the base.
At this point the Kappa line has been cut out and the cheaper board also cut and placed down first on the base, giving the pavement hight above the road.
The reason I always use Kappa Line for anything to been scribed is the way the paper can be removed.
Cheaper board glued onto base.
Now pavement ready to fix.
Pavement on and drying.
The pavement is 5 mm above the road surface.
Next will be the front of the buildings and then the roof line.
Thanks for looking in and the suggestions for kits.
John.Attached FilesComment
Thanks Tim . Made a Morris column, well the cylinder part from an old fax tube. Going to try and shape the top at some point.
Thanks Paul.Comment
JR......Google Vintage European advert. Kiosk images......I found several all different types of tops on them and some really simple in construction that you might try scratching.....g'luck with this.Comment
Thank you Lee.
Well apart from testing a method of aging some paper and finding I could produce some realistic tears on a sample I fell asleep most of the afternoon :upside: Take note you youngsters this will apply to you sooner than you imagine !
Tomorrow is going to be spent doing some scale drawings of shop fronts. I've done some downloads of French street scenes around the late 1940's /early 1950's to give me some ideas.
Hopefully I will post them tomorrow .Comment
Evening all.
They say that time researching is important, well I hope after spending what seems to be hrs last night and the afternoon today will pay off. Armed with photos of French streets, coffee shop and the like I made a start on the drawings.
Doesn't seem a lot from an afternoons effort, but trying to scale from a photo using a picture of a man to gauge heights takes time. Still pleased with the out come.
Would have preferred to have a much bigger base, and therefore had more building in space dictates all of us.
This gives me the outlines to cut out the board and the joins. Lots more to design including those pull out canvas awnings . That should be fun.
This gives a much better idea of what it should look like, again I would have liked the door way a lot wider.
Thanks for looking in.
John.Comment
John,
Excellent prep work mate, making the template certainly does help with the scale and the look.Comment
