Just pulled up at the back John, sorry for being late. I can see some very nice work even from here, and a great idea.
Box Diorama with a Soviet Self-Propelled Gun SU-122
With those tracks done happiness has returned to the cave. To celebrate I decided to make some ammo cases, downloaded a drawing of the SU -122 and set to work.
Basswood is the only real choice , its cuts perfectly and glues well .
Made 5, one will be open showing the internals, the others closed up. Realising to straighten brass wire was simple in the drill while holding thew other end with pliers I was able to end up making some handle grabs as well on the SU .
Some of the .6 mill wire made into end handles. Cases will need a slight damping with a wet cloth , then sanding to remove that fluff.
Meanwhile slowly working on the "Beast "
That brass section sticking out from the centre of the rail will be cut off later.
Thanks for looking in .
John.Comment
Thanks Steve , the rest slowly. Next big thing is the choice of figures. Got to go through all the kit boxes with the odd figure in and then the plastic tubs to see what will do . I can see much surgery again !Comment
I must say, to my uneducated eyes it's really beginning to look like a tank nowComment
Evening , sunny one minute then rain , and heavy at that .
Anyway in the cave some primer has gone on .
Some very small pieces of plastic and equally as small PE went in the bin, too small for me to deal with .Should have been some straps to hold down the spare track links , some ones having a joke !!!!:smiling3::smiling3::smiling3::smiling3:
Hopefully more primer in the tracks , will brush paint now .
John .Comment
