Box Diorama with a Soviet Self-Propelled Gun SU-122
  • Steve Jones
    • 6615
    #166
    Looks like you had a lot of fun with the weathering JR. Lovely work my friend.
    • scottie3158
      • 14221
      • Holbeach
      #167
      John,
      Take a bow Sir, that is looking very good indeed.
        • 15746
        As the others have said John, that is excellent. Very realistic weathering. Very believable.
        • spanner570
          • 15441
          #169
          That is pure magic 453!
          It reminds me of the bilge in the narrowboat we used to own. Spot on for sure.
          I've not seen better and doubt I ever will, and best of all you are always so modest about your most excellent work. I mean that too, John!
          Cheers.
          Ron
          • minitnkr
            Charter Rabble member
            • 7553
            • Dayton, OH USA
            #170
            Excellent work Dzohn.
            • JayCee
              • Aug 2019
              • 1133
              #171
              Very, very nice John. This is looking fantastic. Bring on the rest !
              John.
              • JR
                • May 2015
                • 18273
                #172
                Well, that's looking absolutely superb Mr Race :smiling3:
                VERY realistic indeed,those last couple of pics,especially, could easily be mistaken for a real component
                Excellent stuff!
                Thank you very much Andy, vouchers in post !
                Originally posted by adt70hk
                Now that is really rather good John! Have high expectations of what this will look like when it's finished!
                ATB.
                Cheers Andrew, again very kind of you .
                Thanks Steve.:thumb2:
                John,
                Thanks Paul.:thumb2:
                Cheers Jim.:thumb2:
                Cheers.
                Ron
                570 , your comment is extremely kind, much appreciated .:blow-kiss:
                Thank you Paul:thumb2:
                John.
                Cheers John. Thanks for looking in.
                • Neil Merryweather
                  • Dec 2018
                  • 5199
                  • London
                  #173
                  Fabulous!
                  • Valeron
                    • Jan 2022
                    • 944
                    • Mike
                    • St Albans
                    #174
                    So much detail and so well made and painted.
                    • Graeme C.
                      • 1613
                      • Graeme
                      • UK
                      #175
                      Looking good Comrade Race, dirt & oil in the engine bay, looks like it's been used!
                      • JR
                        • May 2015
                        • 18273
                        #176
                        Fabulous!
                        Thanks Neil.
                        That is very kind of you Mike.
                        Cheers Graeme, glad you agree with the look I wanted.
                        • JR
                          • May 2015
                          • 18273
                          #177
                          Today saw the start of the diorama box. I've spent several days doing fiddley bits of painting of kit, ammo boxes, and new wooden support for engine and gear box lifts, so reached the point where the box needs to be made.
                          You need two boxes, one to house the model and other items, then the outer case to the back of the frame. I'm using a cheaper foam board for all the inner and outer where the removal of the face paper is not required. No good spending money on Kappa Line when dot using the core.
                          Staring with the frame, the backing and glass are removed.
                          Backing board to the frame , this will need to be cut down in opening to allow enough space for the model. You still require enough space to be left between the inner box and the outer for a battery box and wiring .
                          Marked up , ready to remove the surplus inner section.
                          Final opening. Now I can build the inner box to this size. The outer box will be fixed to the outer edge of the frame. Depth has been worked out, there's enough room under neath for the electric's. More tomorrow.
                          John.
                            • 15746
                            There's a lot more planning involved than I imagined. I suppose your background makes measuring and seeing ideas in 3D second nature. It already looks as if you have everything well in hand.
                            • Allen Dewire
                              • 4741
                              • Allen
                              • Bamberg
                              #179
                              That's so true Jim...I just re-read this post and still have no clue about what he's going to do. Knowing John, it will be really good in the end though...
                              Sorry Brother, but I've been staring at the frame for over an hour now and nothing has happened as of yet. It hasn't moved, grown legs or changed color either. In fact, the glass and backing are still on it too......................Taxi!!!!!!!..........
                              Allen
                              • JR
                                • May 2015
                                • 18273
                                #180
                                Thanks Jim, my background does help , luckily I can see the completed idea ahead of actually building it .
                                Allen
                                Hopefully you will be right Dude1. It's too dark to cut any boards to size, I usually do that outside under the car port as the bench is full !
