Box Diorama with a Soviet Self-Propelled Gun SU-122
    • 18932
    Looking very good indeed John. Engine bay work is superb. Great combination of colour and texture. 570 is quite correct as well. I attended a talk given by a Normandy veteran Cromwell commander and his description is exactly what the guy described the engine bay to be like. A boat bilge…..
    • JR
      • May 2015
      • 18273
      #182
      Morning Tim, hope you are improving each day . Thank you for your kind comment .
      Hard to decided how much looks good , too much and it kills it .seems I got it right :thumb2:
        • 18932
        Yep, improving as we go John. The flare was very short lived, thank god, but I have a consultation with the RA pharmacologist this afternoon so might be looking at another meds tweak……then again, they might be looking at the close proximity of starting biologics and getting the embolism. Good job I find this stuff interesting, it could get really boring really quickly……
        As to the weathering, I just throw stuff around until I think it looks right, taking the occasional break to let it dry properly and give me time to get used to it :tongue-out3:
        • JR
          • May 2015
          • 18273
          #184
          Part 2 of the box sections. Sorry no plastic
          First the inner box , made to fit the opening in the frame. It just needs to be slightly wider than the card front.
          Just trial to make sure it all fits, will only be glued together after all on the internals have been worked on, ie the brick wall , the doors and timber work of the barn.
          Front on , just to give a idea of how it will look - minus the outer frame.
          Now face down onto the glass and front . You can see the gap at the bottom right where the electrics, battery and switches will be. The outer case fits to the outer edge of the frame .
          Black board is only because the supplier only had that to make up the 9 white boards he had for an order of 10. It's on the bottom anyway so shan't be seen .
          The full back has been cut out, along with a cut out for a opening flap to access the bottom .
          Hope fully tomorrow I can start the marking of the Kappa line sheet for the brick work and timber.
          Thanks for looking in, comments welcome as usual .
          John.
          • scottie3158
            • 14221
            • Holbeach
            #185
            An excellent bit of building mate.
            • adt70hk
              • Sep 2019
              • 10433
              #186
              Interesting John. Looking forward to seeing how you put this together.
              All the best.
              • wotan
                • May 2018
                • 1150
                #187
                Looking very nice John. Bring on the electricals.
                • JR
                  • May 2015
                  • 18273
                  #188
                  Thanks Paul , but boring for some I feel .:nerd:
                  • JR
                    • May 2015
                    • 18273
                    #189
                    All the best.
                    Hi Andrew, thanks for looking in . Quite complex at times as you are building most of the internals before it all fits together , so some tight measurements needed.
                    • JR
                      • May 2015
                      • 18273
                      #190
                      Hi John, always a exciting time as you well know . When you hope they look as you have imagined
                      • JR
                        • May 2015
                        • 18273
                        #191
                        Morning early birds , another day , looking fwd to getting on the bench . Think it's time for a tidy up !!!!!!!!:rolling::worried::flushed::upside:
                        Before I go any further.
                        • Steve Jones
                          • 6615
                          #192
                          Nice carpentry skills. Keep up the great work my friend
                          • JayCee
                            • Aug 2019
                            • 1133
                            #193
                            Morning John. This is really interesting, as usual. You are very good at these box dioramas. I wouldn't know where to start!
                            John.
                              • 18932
                              Great stuff on the box housing John. Going to look fabulous when it’s all filled with 4BO goodness :thumb2:
                              • Scratchbuilder
                                • Jul 2022
                                • 2689
                                #195
                                Keep going Wobble,
                                Full support from the back seats. madam! do you mind, I have a hernia.....
                                Wibble.
