Box Diorama with a Soviet Self-Propelled Gun SU-122
Thanks mate, will do .
Neil, well I knew you wouldn't feel that way.
Today saw the fixing of the outer box to the frame. Using 3M double sided 5mm wide tape after much measuring and marking out with scrap bits of modelling tape.
Removing the face cover of the double sided tape is fun, the grip is so good I have to use the scalpel blade to hold the sticky section down and a pair if fine tweezers to removes the surface cover.
Fitting the box itself is a one chance affair, go wrong at this point and its back to the drawing board.
All stuck down now the removal
Box on .
Looking ok.
Decided to add a glue line inside the frame / box just to make sure.
Then to make doubly sure some weights on top ! Can't take and risks can you
Then I had a slight tidy up , panic not fellow members of the UTC , only the bench area. Seeing this Christine called for Matron !
Thanks for looking in.
John.Comment
Who's a busy boy then ,looks like a move away from the build for a bit has kept the enthusiasm flowing ,catch up with you soon on the other side. DaveComment
First box done Rick, now the internal and main one is ready to be worked on . Today the Kappa face boards will be exposed and the long job of imprinting bricks on some areas .No need for sedation when working with foam board :nerd:Comment
[ATTACH=CONFIG]n1188052[/ATTACH]
[ATTACH=CONFIG]n1188053[/ATTACH]
Box on .
[ATTACH=CONFIG]n1188054[/ATTACH]
[ATTACH=CONFIG]n1188055[/ATTACH]
Looking ok.
[ATTACH=CONFIG]n1188056[/ATTACH]
[ATTACH=CONFIG]n1188057[/ATTACH]
John.
Really like how the Wood of the front frame finishes it off, excellent stuff!Comment
