Box Diorama with a Soviet Self-Propelled Gun SU-122
  • JR
    • May 2015
    • 18273
    #211
    That looks great Mr.Race. :smiling3:
    Really like how the Wood of the front frame finishes it off, excellent stuff!
    Morning Andy , thanks for looking in . Say hello to Rach and a stroke for Cohan for us .
    • Neil Merryweather
      • Dec 2018
      • 5201
      • London
      #212
      That 3m tape is very good but with the risk of leverage there I think you are wise to use the glue as well
      • JR
        • May 2015
        • 18273
        #213
        Hi Neil,yes it seemed the right thing to do .It's perfect when sitting in the table but if you lift it without support the whole thing could pull away .
        • Steve Jones
          • 6615
          #214
          Lovely update mate.
          • JR
            • May 2015
            • 18273
            #215
            Evening all .
            Little more done, internal support for the dio it's self
            Removal of face paper on the Kappa , showing the reason why I always use it for scribe work.
            Support.
            Cut out insides had been done
            It just lets the base sit below the sightline from the front.
            Base on temporary, those lines on the base floor show the upright side marks.
ID:	1188101Click image for larger version
            Glued with UHU POR . weights on and left to dry.
            The Kappa Line board is the only one that allows you to remove the face paper with out heat, just a block to pull the paper back top as its removed, saves the board snapping in two .
            Other sheet to hold the board down.
            John.
            • rtfoe
              • 9101
              #216
              Hi John, just looking through and expected the engine to start up. Latest carpentry has gotten me confused...have to see the end result to understand better.
              Wabble
              • scottie3158
                • 14223
                • Holbeach
                #217
                All looking very tidy mate.
                • JR
                  • May 2015
                  • 18273
                  #218
                  Wabble
                  Thanks very kind of you to say Wabble . All will become clearer it time , trust me !
                  • JR
                    • May 2015
                    • 18273
                    #219
                    Cheers Paul, getting there slowly .
                    • JR
                      • May 2015
                      • 18273
                      #220
                      A lot done to day, working on foam board.
                      First off the exposed wall , originally had a rough plaster on, fell off with the damp exposing the brick and stone work.
                      The back of the dio has the door in the wall .
                      Been adding the buttress to the main wall
                      Three of these , this one has some damage to the bottom section. Bricks to be scribed on later.
                      Door supports done. The right hand side has a slope from an external section which is not yet built.
                      The door, fun to do .
                      This is why I can't clear up at night, stuff drying over night.
                      Thanks for looking in.
                      John.
                        • 18933
                        Excellent progress John. That’s a lot of scribing
                        • JR
                          • May 2015
                          • 18273
                          #222
                          Thanks Tim. Sure is a lot, actually had a CD on while doing it . A sort of Zen moment !
                          • Mini Me
                            • Jun 2018
                            • 10711
                            #223
                            Nice JR, Not quite sure how all this is going to work.......I'm sure you have a good handle on it and that building is on schedule according to Matron, so no need to give you the Hypo!!
                              • 15746
                              Looking excellent John. You're in your element. That wall will paint up really nicely.
                              • JR
                                • May 2015
                                • 18273
                                #225
                                That's two of them Rick , I have a plan , but most is done on the go !
                                No Matron is cleaning her motor bike , taking about fitting afterburners ! Apparently she has friend at the US base Alconbury.
