Tamiya Wespe 1/35 scale.
  • Scratchbuilder
    • Jul 2022
    • 2689
    #181
    Much cheaper , but has deadly results!
    Only when you traf in a lift full of nuns....
    • Scratchbuilder
      • Jul 2022
      • 2689
      #182
      Going now before I get into trouble....
      • JR
        • May 2015
        • 18273
        #183
        EMAIL incoming .
        • Graeme C.
          • 1611
          • Graeme
          • UK
          #184
          Coming along nicely John, the figures are nice.
          I hope Mike is on India Pale Ale.....
          • JR
            • May 2015
            • 18273
            #185
            After the glue and paint problem I carried on .
            Using this camo pattern .
            I've come up with this.
            Don't want it very pronounced . Apart from the streak on the front armour plate I'm more than pleased. Not bothered by the missed paint on the wheels either, they can be covered by street debris.
            The reason for the white on the hull will become apparent later.
            Varnished with AK 3RD Gen.
            Testes the spray after mixing on a sheet of white printer paper as recommended by David Lovell. A couple of light passes were made.
            Drying now over night by a heater , should start the weathering tomorrow.
            Thanks for looking in.
            J
            • JR
              • May 2015
              • 18273
              #186
              Hi Graeme, posts crossed. Thank you. With any luck it will be that !:smiling3:
              • Mini Me
                • Jun 2018
                • 10711
                #187
                Looking good JR! :thumb2:
                • JR
                  • May 2015
                  • 18273
                  #188
                  Thanks Rick .
                  • adt70hk
                    • Sep 2019
                    • 10428
                    #189
                    That's coming on beautifully John.
                    Keep up the great work!!
                    ATB.
                    • JR
                      • May 2015
                      • 18273
                      #190
                      ATB.
                      Thanks Andrew, feel a lot happier now I have the AB problem sorted .
                        • 15744
                        Looks good to me John. Glad the airbrush issue is sorted. Things like that can be very frustrating.
                        • JR
                          • May 2015
                          • 18273
                          #192
                          Your right Jim , got to the point of dreading using it .
                          • JR
                            • May 2015
                            • 18273
                            #193
                            Today haven given the varnish over night to dry I set too on the weathering.
                            These were in a box of paints belonging to my late father, so this was the first time since 1970 they have been used. Think or hope he would be pleased to see them in use again.
                            Having put a spot of paint on a piece of cardboard as seems the correct way I set off.
                            This was before ( above )
                            Back removed for internal shot.
                            slight rust along the base and some streaks from the tarpaulin clips
                            How on earth 4 crew members got inside that back section ! as they normally had a 5 man crew.
                            Thanks for looking in .
                            J
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #194
                              Nice touches JR! :thumb2:
                                • 18932
                                These were in a box of paints belonging to my late father, so this was the first time since 1970 they have been used. Think or hope hi would be pleased to see them in use again.
                                [ATTACH=CONFIG]n1196585[/ATTACH]
                                [ATTACH=CONFIG]n1196586[/ATTACH]
                                [ATTACH=CONFIG]n1196587[/ATTACH]
                                [ATTACH=CONFIG]n1196588[/ATTACH]
                                [ATTACH=CONFIG]n1196589[/ATTACH]
                                J
                                Looking very good John. I would think the other crew would be handing in ammo?
