Tamiya Wespe 1/35 scale.
  • JR
    • May 2015
    • 18273
    #256
    No photos as the board is damp and gives the wrong colours , but I've made up a mix of wall filler which was extremely fine, added several drops of grey and sandstone paint mixed well and applied to the brick work .
    Frightening I can admit to cover all that previous work with a slurry of grey filler. Then wiping it off with a damp sponge in a downward movement. Not too hard as you will draw out the filler . Finding the amount of dampness needed to remove only the filler from the face of the bricks is unnerving. I found patting the surface with kitchen towel helpful at the end . Both sides are now sitting in the warm awaiting from tomorrow.
    Then it's more brick painting , this time singularly to bring out the colour again . The application of mat varnish over the brick face before this is definitely worth it .
    Hopefully tomorrow will bring some photos .
    John .
    • Mini Me
      • Jun 2018
      • 10711
      #257
      Sounds like good progress JR....careful on the drying temp for the wallboard filler....too high and it will crack.
      • JR
        • May 2015
        • 18273
        #258
        Indeed Rick, good point ,luckily it's not in direct line of fire from the heater so should be ok .:thumb2:
        • JR
          • May 2015
          • 18273
          #259
          After drying over night I started painting each brick separately. Having a mix of colours I began . Took most of the day, had a long break at lunch time , then returned to the bench.
          Managed to do one side , the front , so tomorrow will tackle the side , which is a lot smaller .
          Already had a test on a section of wood for the doors, need that worn look from faded paint .
          From this
          To this.
          Front , next will be a black tyre wash , very thin to pick out the brick face .
          A long involved job, just switch off and paint !:nerd:
          Thanks for following.
          John .
          • outrunner
            • Apr 2019
            • 2420
            #260
            You are obviously a patient man, well done with the brickwork.
            Andy.
            • yak face
              • Jun 2009
              • 13849
              • Tony
              #261
              Top work john the brickwork looks amazing , loving the doors too . Just wondering when you can fit me in to re-point my house , mates rates of course! :smiling5:Cheers tony
              • JR
                • May 2015
                • 18273
                #262
                Andy.
                Thanks Andy .Patient when modelling but not when shouting at the TV !!
                • JR
                  • May 2015
                  • 18273
                  #263
                  :smiling3: Thanks Tony. Glad you like it .
                  • Neil Merryweather
                    • Dec 2018
                    • 5199
                    • London
                    #264
                    Stunning John!
                      • 15737
                      I'd call that mortaring a real success. Definitely a method to remember.
                      • JR
                        • May 2015
                        • 18273
                        #266
                        Stunning John!
                        Many thanks Neil.
                        Thanks Jim, does seem strange wiping it off though and smearing the face work.
                        • JR
                          • May 2015
                          • 18273
                          #267
                          Today saw the finish to the bricks, ------------------I think ?
                          Cleaned out the widow opening from the back with a file and the frame fits. The photo is taken from the inside.
                          Then came to wash coat with tyre black .
ID:	1197985Click image for larger version
ID:	1197986Need to remove some of the lower wash from the side section. I will remake the anchor plates later and refix the hoist section.
                          Thanks for looking in.
                          John.
                          • Mini Me
                            • Jun 2018
                            • 10711
                            #268
                            Just booful John!
                            • JR
                              • May 2015
                              • 18273
                              #269
                              Just booful John!
                              Thanks Rick. Those door tomorrow and steel work.
                              • Si Benson
                                • 3572
                                #270
                                Top job on the painting and mortar John, brings the brickwork to life perfectly…..very realistic :thumb2:
