Lovely lead work John. Looks fantastic.
Tamiya Wespe 1/35 scale.
Many thanks Neil.
Thanks my friend :thumb2:
Cheers Tim .Comment
The roof is done, photos later .
Now going to get up !!!! and even more of a shock have a tidy up !!!!!!!
Mrs R is going to supervise.
Hopefully more later:smiling3:.Comment
Right having had the minor tide up of the bench I carried on with the flashing .
The second batch has been cut , and all the flashing has been treated with MR Hobby metal primer. As a side I was looking for a suitable cleaner for a brush when using this primer, but found out the brush when put back into the primer returns to a soft state from the solid one it dries as. So don't bother with any cleaner !:nerd:
Over all view of the base and building .
The roof, took a lot longer after finding two rows of tiles with PVA was enough at one time . Normally I would get 4 rows done in a day then the chest infection put paid to that !
The flashing , now drying . Will paint before fixing as want to keep the brick work clean .
Tomorrow brings the PVA and primer coat ready for the tile work later .
Thanks for following.
JComment
Finished the gutting, down pipe went in ok , but the middle join came apart, any way a dap of CA seems to have done the trick.
Next was the flashing for the roof to brick. Covering a piece of Pewter with some Tamiya Tape and finding the angle of the roof I penciled in the brick spacings. Then still leaving the tape in place cut the marked parts out.
Going to have to do it in short sections, starting at the bottom and overlapping where needed. Really pleased with how it worked out using the tape on top.
[ATTACH=CONFIG]n1199168[/ATTACH][ATTACH=CONFIG]n1199169[/ATTACH]
Flashing not fixed, but it shows the method.
John.Comment
