Tamiya Wespe 1/35 scale.
Super detailing John. I like those crates very nice. Glad you got some garden time in mine is soaked with rain and I need to plant.Comment
Great stuff John, two things to consider for the roof tiles. How old is the building and how much moss would have gathered under each step of the tile and with light snow...how does it fall and gather? Looking forward for more eye candy.
WabbleComment
Many thanks Jim.
Thanks Pete.
Very kind of you Paul .Comment
To day while sitting in the sunshine I used some VMS tarp paper and the liquid paper shaper.Used it before and is just the job, you can apparently use normal printer paper ,but not had to resort to that yet
First thing this morning was to glue the cases together. Once dry the paper was soaked in the solution and draped over the cases .
Using a brush and more liquid you wrangle the sheet, trying to get life like folds .
Once dry I'll brush paint the tarp .
Also did some chipping on the fuel drums, using Ak chipping .
Starting with the primer yesterday allowing to dry over night I applied a good coat of the chipping .Left it until it was dry and then brush painted the finished top coat.
With that dry and a bowl of clean water ready a small brush was soaked in the water .Repeated scrubbing , (not to hard as the paint was just dry) gave a reasonable worn look.
Next will be some thin lines where the barrel has been rolled and some staining around the top .Thanks for looking in, off to do the tea .
John .Comment
