Tamiya Wespe 1/35 scale.
I just cannot get my head around the realism you and other diorama builders acheive, it boggles the mind as to how many different skills and techniques you have mastered to produce such perfection.
Kindly award yourself the dogs dangly bits gold plated and mounted on a scratch built plinth.
Cheers Mick .Comment
To day while sitting in the sunshine I used some VMS tarp paper and the liquid paper shaper.Used it before and is just the job, you can apparently use normal printer paper ,but not had to resort to that yet
First thing this morning was to glue the cases together. Once dry the paper was soaked in the solution and draped over the cases .
Using a brush and more liquid you wrangle the sheet, trying to get life like folds .
[ATTACH=CONFIG]n1200879[/ATTACH][ATTACH=CONFIG]n1200877[/ATTACH][ATTACH=CONFIG]n1200878[/ATTACH]
Once dry I'll brush paint the tarp .
Also did some chipping on the fuel drums, using Ak chipping .
Starting with the primer yesterday allowing to dry over night I applied a good coat of the chipping .Left it until it was dry and then brush painted the finished top coat.
With that dry and a bowl of clean water ready a small brush was soaked in the water .Repeated scrubbing , (not to hard as the paint was just dry) gave a reasonable worn look.
Next will be some thin lines where the barrel has been rolled and some staining around the top .[ATTACH=CONFIG]n1200886[/ATTACH]Thanks for looking in, off to do the tea .
John .Comment
Hope your well .Comment
