M10 LEND LEASE BY ACADEMY 1/35 AMBUSH .
  • Neil Merryweather
    • Dec 2018
    • 5181
    • London
    #151
    Lovely stuff John
    • Andy T
      • Apr 2021
      • 3239
      #152
      Very nice John, a fine bunch of lads.
        • 15641
        Excellent work with the figures John.
        • Si Benson
          • 3572
          #154
          Crickey! You’ve been a busy boy painting that little lot :surprised:
          Splendid job and I see you’ve even got markings down on their helmets….impressive!
          • BattleshipBob
            • 6785
            • Bob
            • Cardiff
            #155
            Very, very, very late John
            Have a chair, will squeeze in at the back?
            • JR
              • May 2015
              • 18273
              #156
              Lovely stuff John
              Thanks Neil.
              Cheers Andy.
              Thanks Jim, really enjoyed doing the Germans .
              Yes even managed those very small decals Si. Used a piece of plastic card. Placed the decals on and them a couple of drops of water from a pipette . That way they just came loose , picked them up with the tip of a small brush and put them in place .
              Always a seat for you Bob down the front . :thumb2:
              • JR
                • May 2015
                • 18273
                #157
                Meant to mention the tracks, for me a length like that is great. However they do NOT like paint , well Acrylic anyway . I sprayed them with a track AK 3d gen primer, it all came off , sticking to the road wheels . Some thing to think about for anyone with this kit .
                • Si Benson
                  • 3572
                  #158
                  Just your luck John! You get a kit without individual tracks and now the paint won’t stick :tired:.
                  Well if the paint won’t stick, Bring on the mud!!
                  • JR
                    • May 2015
                    • 18273
                    #159
                    Hi Si, hope you and all at Benson Villa's are well .
                    Strange track mixture, even read it somewhere..
                    • JR
                      • May 2015
                      • 18273
                      #160
                      Started the best part ( for me ) .
                      Starring with the XPS form sheet , cut to size after marking in with tape free hand on the hot wire cutter , then to gain depth added a slightly thinner section.
                      Cutting up a 50 mm thick piece roughly in half gave enough material to make the front for a building and the raised area .
ID:	1209784Click image for larger version
                      When gluing I use a piece of grease proof paper to protect a clean cutting mat.Usung Deluxe white quick drying glue held down and together with steel bars .
                      Although recommended to use the white glue I'm not convinced as the section above was still unstable 3 hrs later. Is a 5 minute glue on timber and paper ,but not on the XPS.
                      Leaving the rest to dry I cut a piece of Kapa foam board for the stone sets.
                      Well worth the cutter and rail for a perfect 90deg cut.
                      This is now stripped of one face of the backing paper ready to imprint stone sets .
                      The cut out section on the bottom right hand front will be a large creater, this will be deep enough for some of the Germany ambushers to hide in .The others will be in battle damage opening in the building behind the M10 .
                      Thanks for looking in, comments are welcome .
                      JR
                      • Andy T
                        • Apr 2021
                        • 3239
                        #161
                        I'll pull my chair a little closer for this part John.
                        • JR
                          • May 2015
                          • 18273
                          #162
                          Your welcome Andy, if I can get the sets as good as yours in the last dio I'll be pleased .
                          • scottie3158
                            • 14197
                            • Holbeach
                            #163
                            Hi John,
                            Bring on the magic.
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #164
                              Go for it JR.....just like you to save the best part for last!
                                • 15641
                                Loving watching you working on this stage of a dio.
