M10 LEND LEASE BY ACADEMY 1/35 AMBUSH .
  • JR
    • May 2015
    • 18273
    #166
    Hi John,
    Bring on the magic.
    Thanks Paul.
    Originally posted by Mini Me
    Go for it JR.....just like you to save the best part for last!
    Indeed Rick .:tongue-out3:
    Originally posted by Jim R
    Loving watching you working on this stage of a dio.
    Thank you Jim, hope you enjoy.
    • JR
      • May 2015
      • 18273
      #167
      Did some more this morning, now waiting for a day to allow the pva to dry. Overnight the previous sections had dried, so have used PVA again for the Kappa line backing to XPS .
      Using a drywall sanding plate fitted with 120 grit paper I cleaned the edges of any dried PVA , definitely use a mask for this as there's plenty of dust .
      Once that was done, I prepared the XPS with a coat of normal PVA , once done I did the same to the paper side of the Kappa line foam board and left till that became tacky.
ID:	1209816Click image for larger version
      Still moveable at this stage, so lined up and some weights applied to the top. ( Other semi skimmed milk brands are available at different supermarkets.)
      Tomorrow the crater will have a layer of Sculptamold, much mess I feel :smiling3:.
      Thanks for looking in.
      John.
      • Graeme C.
        • 1604
        • Graeme
        • UK
        #168
        The exciting part, seeing where everything goes on the dio. Bring on the sculptamold (whatever that is) John, we like a bit of mess. At least it's not fire.....:rolling:
        • JR
          • May 2015
          • 18273
          #169
          Thanks Graeme, sculptamold is a sort of plaster and shredded paper, mixed with water and used as a base .Dries over night to a solid .
          No fire on this as the foam would all melt :disappointed:
          • JR
            • May 2015
            • 18273
            #170
            Still working away on the base and the backdrop of buildings. Leaving any gluing to dry fully overnight so some things take much longer.
            First the upright of the building, decided that a straight run was uninteresting so going to have a slight setback of the second part.
            Taking two separate sections of XPS , approx 12 mm thick, this time in white I did a 45% cut, stops that line that you get when doing a but join .
            Second part will be joined to the first .
            Today cut some backing foam board a cheap one that I prefer for none scribing , This just gives the XPX a little more strength .
            Cut and glued this to the XPS sections. .
            Leaving to dry until tomorrow. Then will start on the cut outs for widows, The gap between the XPS and the foam board is for later when I show some damage . Joists to do as well .Might be some burnt sections as well !!!!
            For Graeme C. , the first layer or of Sculpty, now dry .
            Will build this up as required.
            Already cut some stone sets that would have been disrupted , these will be painted later.
            Slow is the only way.
            Thanks for looking in, comments always welcomed, or abuse from the rabble.
            John.
            • JR
              • May 2015
              • 18273
              #171
              Spent to day using the Patented Wibble Brick Scribing Tool .
              Soon had the bricks scribed and having filed down a dental tool to the width marked out the widths.
              After all this I applied a mix of filler to represent the render .A lot of it will have been dislodged when the building was hit .
              Leaving it over night to dry , doing a sand first to give a uniform thickness. If needed a nother thin layer will be applied .
ID:	1210308Click image for larger version
              Comments welcome .
              • Allen Dewire
                • 4741
                • Allen
                • Bamberg
                #172
                Outrageous work Dude 2!!! You are so in your element now and it shows...I'm loving this Buddy and PM tonight or in the morn. Lotsa table doings at the moment...
                Dude 1
                  • 15703
                  Great stuff John. Another masterpiece in the making.
                    • 18907
                    Miles behind on this, sorry john. Just had a catch up though, and I’m mightily impressed. It’s coming on great. Figures look exceptional mate. Nice one :thumb2:
                    • Mini Me
                      • Jun 2018
                      • 10711
                      #175
                      Looking the part JR........you always get this building lark in its place PDQ. As to the fire, I'll let Matron decide how involved you get with that!
                      • David Lovell
                        • 2186
                        #176
                        Nothing wrong with a bit of rendering ,like your thinking on it being dislodged by impact/concussion ,we recently had to re render the top half of a house the two sides that weathered the most practically fell off the others were a lesson in forgotten words and phrases only reason I mention John was the amount of stuff that needed cleaning up and showing the skip we had hardboard sheets downbefore scaffolding went up on top to make cleaning up easy but you'd be surprised just how much was on the floor so don't hold back on the dio ,I feel a often overlooked detail on a lot of dio's if the top half of a place caves in roof and all it fills the building up to chamber joist you never see that on a dio or if you do its very rarely. Still as usual keep up your excellent work and thoes small attention to details that make yours stand up above. Dave
                        • JR
                          • May 2015
                          • 18273
                          #177
                          Dude 1
                          Very kind of you Dude1. No instructions to fathom out,no damned plastic tracks:angry:
                          Just fun now .
                          Thanks Jim:smiling2:
                          No problem Tim.
                          Really enjoying figures these days, got some new brushes as your suggestion from Rosemary now very much easier .
                          The best part Rick :nerd: I believe Matron is currently looking for Andy Smith after he said he was going to build a bi plane , shock horror :surprised:
                          Fully agree Dave, all the render would have landed on the road, I'll make up some flat sheets of filler spread out onto some greaseproof paper . Will have to add a little PVA to strengthen it. Don't know if to add a coat of mat varnish and then paint. Adding water to the surface of the dried filler will weaken it .Thinking hat on .
                          Good suggestion thanks
                            • 15703
                            How about mixing some acrylic paint with the filler before you spread it out?
                            • Steven
                              • May 2018
                              • 589
                              #179
                              Late to this (what else is new...:rolling:,)-looking fine, John I am pulling up a chair mate :thumb2::thumb2:
                              • langy71
                                • 1950
                                • Chris
                                • Nottingham
                                #180
                                Apologies for missing this John, but glad i've finally dropped in for an update, It's looking mighty fine so far mate.. :thumb2: :thumb2:
