M10 LEND LEASE BY ACADEMY 1/35 AMBUSH .
  • scottie3158
    • 14201
    • Holbeach
    #181
    John,
    Looking good mate the buildings are really taking shape.
    • Si Benson
      • 3572
      #182
      Coming along very nicely Mr Race :thumb2:
      • JR
        • May 2015
        • 18273
        #183
        Originally posted by Jim R
        How about mixing some acrylic paint with the filler before you spread it out?
        Good idea Jim,I'd have to get the overall colour done for the rest of the remaining render. Wouldn't be too much cost as would use cheap acrylics.
        You'll see in a minute some tests I'm doing with adding PVA to the filler mix. Hopefully this will make the sheets I've done stronger for the fallen render . The next stage after it's dried is a gentle sand, if the PVA will allow .Then I was going to put a coat of flat varnish . Hopefully this will stop any of the filler mix from damage when I paint.Of course If I did as your suggestion it would have been already painted
        Originally posted by Steven
        Late to this (what else is new...:rolling:,)-looking fine, John I am pulling up a chair mate :thumb2::thumb2:
        Welcome , Steven tea or coffee ?
        Originally posted by langy71
        Apologies for missing this John, but glad i've finally dropped in for an update, It's looking mighty fine so far mate.. :thumb2: :thumb2:
        Hi Chris,no problem the first part was rather boring just gluing the base anyway .Thanks for looking in .
        John,
        Hi Paul, well they were ! just broke a section off ,much grief :surprised:.The bottom right hand side took a knock sanding. Now glued back on thankfully.
        Hi my friend, thank you . :thumb2:
        • JR
          • May 2015
          • 18273
          #184
          Having just repaired the bottom right hand as mentioned to Paul,my fault trying to sand with out full support underneath.
          Still it's ok , the glue will dry fully over night .
          Hopefully the filler test will dry and well .
          Thinn the mix with the PVA will take a little longer.
          Some additional filler added where it looked too thin .
ID:	1210365Click image for larger version
          These two photos show 4 sections of filler PVA mix . Not bothered about the folds in the backing paper, half of it will break up when the paper is removed.
ID:	1210363left hand side is straightforward filler mix, while the right has PVA added .Just want to see the reaction when coated with a thin coat of mat varnish .
          Thanks for looking in.
          Jr
          • David Lovell
            • 2186
            #185
            Very kind of you Dude1. No instructions to fathom out,no damned plastic tracks:angry:
            Just fun now .
            Thanks Jim:smiling2:
            No problem Tim.
            Really enjoying figures these days, got some new brushes as your suggestion from Rosemary now very much easier .
            The best part Rick :nerd: I believe Matron is currently looking for Andy Smith after he said he was going to build a bi plane , shock horror :surprised:
            Fully agree Dave, all the render would have landed on the road, I'll make up some flat sheets of filler spread out onto some greaseproof paper . Will have to add a little PVA to strengthen it. Don't know if to add a coat of mat varnish and then paint. Adding water to the surface of the dried filler will weaken it .Thinking hat on .
            Good suggestion thanks
            John i hope you don't think I was criticising or telling you what to do it was just a observation/ thought on the recent job we did i feel awful now especially as your trying to litter the place with render/debris sorry mate Dave.
            • JR
              • May 2015
              • 18273
              #186
              Don't be Dave , I knew very well you weren't being like that . I normally have a tub of thin sections , your post was a reminder. PM sent.
              • JR
                • May 2015
                • 18273
                #187
                At the moment waiting for various timber sections to dry .
                Brick work has be indented again , removed the sanded filler
ID:	1210447Click image for larger version
                Just takes time !
                JR
                • Andy T
                  • Apr 2021
                  • 3239
                  #188
                  Just takes time !
                  JR
                  But when it looks as good as that John, I'm sure it's more than worth it!
                  • JR
                    • May 2015
                    • 18273
                    #189
                    Cheers Andy:thumb2:
                    • Neil Merryweather
                      • Dec 2018
                      • 5185
                      • London
                      #190
                      John that looks fantastic!
                      • Si Benson
                        • 3572
                        #191
                        Well if I didn’t know better, I’d say you’d been pinching the timbers out of my attic!
                        Looking very convincing :thumb2:
                          • 15687
                          Looking very good John.
                          • scottie3158
                            • 14201
                            • Holbeach
                            #193
                            looking excellent mate.
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #194
                              JR joinery at its best.....and no burnt timbers? Matron has me standing by with the extinguisher........just in case
                              • Lee Drennen
                                • 7711
                                #195
                                Nice updates and flame retardant
