M10 LEND LEASE BY ACADEMY 1/35 AMBUSH .
  • Andy the Sheep
    • Apr 2019
    • 1864
    • Andrea
    • North Eastern Italy
    #256
    Wonderful! Seen your achievements, I feel the need to give a try to foam modelling; the results, yours at least, are in the ego-rewarding category. :thumb2:
    Unfortunately, I still have to find the Italian equivalent of 4D modelshop. :disappointed2:
    • wotan
      • May 2018
      • 1150
      #257
      Very nice John. Watching the progress of a masterbuilder.
      • JayCee
        • Aug 2019
        • 1131
        #258
        Excellent brickwork and carpentry, as usual, John.
        John.
        • JR
          • May 2015
          • 18273
          #259
          Wowsa John!
          Thanks Neil :nerd:
          Originally posted by Tworrs
          Excellent John.
          Many thanks Garry.
          Originally posted by rtfoe
          Looking very interesting Wobble.
          Wabble
          Wabble thank you .
          Lovely stuff John
          Really liking that a lot:thumb2:.
          Cheers Andy . Hope you ok down there.
          Thanks Andrea, there must be someone local that sells XPS foam ?
          Very kind of you to say John. Cheers .
          John.
          Thanks John.:smiling:.
          • Graeme C.
            • 1597
            • Graeme
            • UK
            #260
            The base & building look great John, the closed in streets would be difficult for armoured vehicles.
            • JR
              • May 2015
              • 18273
              #261
              Spent a lot of time today using the hot wire cutter, after much time spent slicing thin scrap sections I've must have made enough roof tiles to last me out !
              Did manage to cut out the building , didn't get time to scribe , so the photo shows how it will look.
              Also added a nother couple of roof joists to the tower .
ID:	1212224Click image for larger version
ID:	1212225Click image for larger version
ID:	1212226Click image for larger version
              Thanks for the comments and for following .
              • JR
                • May 2015
                • 18273
                #262
                Posts crossed Graeme.Thanks.
                Yes not the best place for tracked armour, it certainly won't be soon !
                • Si Benson
                  • 3572
                  #263
                  Evening Mr R, Seems I missed an update :surprised:
                  Some very nice stone work and carpentry skills….looking excellent
                  • JR
                    • May 2015
                    • 18273
                    #264
                    Thank you Si.
                    • adt70hk
                      • Sep 2019
                      • 10400
                      #265
                      Hi John.
                      Just had a catch-up. Sorry you had to start again with the ground work but that knew one is coming on very nicely.
                      Also LOVE the corrugated sheet idea! Very interesting!!!
                      ATB
                      • adt70hk
                        • Sep 2019
                        • 10400
                        #266
                        Now you’re saying it I remember seeing you do them before ….. Works very nicely, I wonder if I could scale it down to 1/72 convincingly :thinking:
                        So I was thinking exactly that. There must be a way......
                        What about if you glued cocktail sticks or something round and thinner onto two wooden blocks the width apart of whatever you're using. Then push down......if you don't push too hard you shouldn't get a flat spot on the top where you hit the block.
                        ATB.
                        • Andy T
                          • Apr 2021
                          • 3239
                          #267
                          ATB.
                          I made a very similar tool for the only corrugated roof I've done. Simple, but it did the job with a bit of persuasion. I'll send you a picture of it once I'm out in the shed.
                          • adt70hk
                            • Sep 2019
                            • 10400
                            #268
                            Thx. Andy!
                            • The Smythe Meister
                              • Jan 2019
                              • 6248
                              #269
                              Yes, we're fine thanks John,a bit wet'n windswept, but absolutely fine :thumb2: .
                                • 15653
                                Fine building work there, John.
