M10 LEND LEASE BY ACADEMY 1/35 AMBUSH .
  • BattleshipBob
    • 6803
    • Bob
    • Cardiff
    #286
    Thank you Bob, normal plain envelope in grate near your house.
    Hope the ink is dry this time!!
      • 15722
      Quality work all the way John. Looking superb.
      • JR
        • May 2015
        • 18273
        #288
        Not my fault if Welsh Water keep digging up your road, I think they are hoping to find it before you.
        Thanks Jim.
        • adt70hk
          • Sep 2019
          • 10415
          #289
          That's really looking the business John. Up the with your best!
          ATB.
          • JR
            • May 2015
            • 18273
            #290
            ATB.
            Thank you Andrew.
            • JR
              • May 2015
              • 18273
              #291
              Not got much done as been battling with a new phone
              Couldn't do the normal transfer of apps as the Internet on the old phone had packed up .So had to do it app by app , at least its now done.
              Decided that separate roof tiles at the size required was too time consuming. Cut some very thin section and have glued it in lengths, then cut the tiles into it .
              Sorry you'll need to turn your screen or lie on the table :smiling3:
              Thanks looking in , cricks to necks claims not considered .
              • Neil Merryweather
                • Dec 2018
                • 5193
                • London
                #292
                Looking good John. Looks like you glued them then scribed them afterwards? Next time I would try cutting the tiles into the edges of the strips before you stick them down.makes it easier to avoid damaging the tiles underneath.
                I would have used card, but the foam makes the damage easier to represent :thumb2:
                • JR
                  • May 2015
                  • 18273
                  #293
                  Yes, see what mean Neil. I'll give that a try. Need to rember not to cut the whole width .Thanks.
                  • JR
                    • May 2015
                    • 18273
                    #294
                    Tried Neils suggestion, seem better.The only thing is the build up as you go up the roof, happened with the thicker tiles as well. Might start again with proper joists and laths to glue a strip of tiles down, so there is less tiles under the over hang. Not bothered about how long it takes, just it must look right.
                    • scottie3158
                      • 14208
                      • Holbeach
                      #295
                      I agree mate and given your attention to detail that's the right call.
                        • 15722
                        Looks good already but I can see what Neil means. I have no doubt you'll end up with an excellent roof.
                        • Allen Dewire
                          • 4741
                          • Allen
                          • Bamberg
                          #297
                          Yeah Brother!!! What Jimbo said and it better not leak when it's done either!!!......PM in the morn...
                          Allen
                          • JR
                            • May 2015
                            • 18273
                            #298
                            Thanks Paul, I'll give it a go , will keep the card roof just in case .
                            Cheers Jim. Hopefully, or I'll take up free style ironing !
                            Allen
                            Look fwd to it brother .
                            • JR
                              • May 2015
                              • 18273
                              #299
                              Started on the roof trusses.
ID:	1212949Click image for larger version
                              Got this far by close of play. The cross ceiling joist are not yet fixed. Spend a bit of time cutting .8 mm laths for the tiles.
                              Thanks for following.
                              • Si Benson
                                • 3572
                                #300
                                Nice work with the timbers :thumb2:
                                Bet the laths where a bit fiddly at 0.8mm :surprised:
