M10 LEND LEASE BY ACADEMY 1/35 AMBUSH .
Arh Dear Matron, I shall eagerly wait her arrival Graeme.
Jim , the days of me being allowed a pipe are back in the annals of time . Mrs R would not be pleased you are very right !!!!!!Comment
Don't forget to only fix every third row if you have to climb up for repairs you can slide tiles up and use battons as foot holds :tongue-out: :thumb2:.Comment
Evening all .
Much has been achieved in the last few days, some very tedious like cutting 15 mm lengths of timber for windows. They are still in work.
Did the roof on the house.
Those wisps of glue from the uhu are annoying, taken one lot off before the painting, and there are more !
Used AK set for the timbers, as they are in the dark the colour stays roughly the same as new .
Managed the ridge tiles , used very thin Pewter, also on the flashing.Hopefully those tiles on the right look as if the hit on the roof has caused the timbers to jump and thus dislodging the tiles.
While I had the cheap acrylic paint out I did both buildings their first coat.
Mainly dry brushed, will need to go over the whole area again with other colours.
Monday saw the corrugated sheets get a coat of steel, applied with the AB, I'd already painted them with metal primer MR HOBBY and some dark and rust colours. This time I sprayed across the sheet. this coated the tops , leaving the rust in the folds.
C& C welcome, thanks for looking in.
John.Attached FilesComment
Much has been done, but a very slow process. Takes time to create damage . Still more painting to be done.
Last two photos are of rubble , first was the remains of roof tiles, then the brick work.This when dry will have dry brushing to show the differing colours of the brick, also some mortar. think next time I do some dipping in to paint I will leave the material on a tile and not paper .
Thanks for looking in C& C welcome .
John.Comment
That's looking fantastic.... And that was just the fire!!!:thumb2::thumb2::thumb2::thumb2::thumb2::bl ow-kiss-2::blow-kiss-2::blow-kiss-2::blow-kiss-2::blow-kiss-2::blow-kiss-2:
In all seriousness sorry for getting behind on this John. It really is coming on beautifully!
Hope all is well with you otherwise?
ATB.
AndrewComment
Thank you 570, easier joists to lift
453
ATB.
Yes all good thank you.Comment
