English Civil War - Cavalry charge!
  • Peter Gillson
    • 2594
    #16
    Originally posted by Jim R
    I am sure you'll make a great job of this. Looking forward to the butchery. Just remember horses only have four legs. It's easy to get carried away with all this chopping :smiling:
    jim - surely they have ten - 2 rear legs and 2xfore legs. sorry.
    • Peter Gillson
      • 2594
      #17
      Here is this evening's work.
      The two rear quarters need to be spread apart a little so filling with putty is needed, the pin is to connect it to the front parts:
      This part will donate the front quarter, leg and center sections:
      the other side was cut in a similar way, with them all put together the result is this:
      It will all be left to set/cure overnight, tomorrow a lot more filling, sanding and detailing to be done, and one more pin to be added.
      • Neil Merryweather
        • Dec 2018
        • 5189
        • London
        #18
        Great to see someone else going old school, Peter :hungry:
        • rtfoe
          • 9086
          #19
          Ever played the song "The hip bone connected to the thigh bone..." while butchering Dr Peter? :smiling6:
          You've got good connections.
          Wabble
            • 18907
            Looking very interesting indeed Peter. Not a period we see modelled very often, and you are making a great start on it. One thing to keep in mind though, ECW horse, at least those that fought from horseback, came in two types. Gallopers and trotters. Only the lightly armoured gallopers would charge in like this. The more heavily armoured trotters would simply trot in and thrash around with their swords, relying on armour protection to keep them safe.
            • spanner570
              • 15403
              #21
              Excellent 'Butchery' Peter.
              In the heat of battle with all the noise going on, horses could well be wounded and at best frightened to death.
              Surely Tim, with a few hundred souls trying to slaughter each other in a relatively small area, the animals (and/or riders) could not be 'Type cast' to behave as they should?
              Just a polite thought.....
              Ron
                • 18907
                Ron, I understand what you mean, but cavalry were probably the highest trained military formations of the day, and followed either the Dutch (trotters) or the Swedish (gallopers) models of training. Horses were also acclimatised to gunfire before being taken into front line service. Behaving to type is exactly the point of this training. Not saying what you describe didnโ€™t happen, but that military discipline was designed to minimise it as much as possible.
                These tactics were considerably different to the flat out gallop with sabres swinging cavalry charges most of us are familiar with from Napoleonic and Crimea war battles, by the way. Those tactics developed from experience derived from this war, amongst others.
                Trotters advanced (usually six ranks deep) at a fast trot to within pistol shot range of the enemy, discharged their pistols and wheeled away so that the next rank could then fire. When all ranks had fired they drew swords and rode into contact with the enemy at a fast trot, keeping formation knee to knee.
                Gallopers did charge (three ranks deep) in at a faster pace, but, they didnโ€™t use swords until after contact. Again they charged knee to knee, sometimes literally locked together to maximise shock. At the point of contact they fired their pistols into the enemy, then drew swords to fight hand to hand. Galloper tactics became more common as the war progressed because it was seen to be more effective.
                In both cases cavalry received an opposing charge at the halt, to maximise the effect of their carbine fire on the charging opponents. Cavalry almost always fought the opposing cavalry, by the way. After all, charging home against a pike block would be all but impossible.
                Very interesting period. I used to work with a sealed knot reenactor and borrowed and read quite a few books from him. He was late for work on a Monday once. He had come straight from a reenactment at the weekend, and as he had pikes on the roof of his camper and swords in the back the MOD police wouldnโ€™t let him on site :upside:
                All irrelevant though, however. No matter how Peter puts this together it will look superb Iโ€™m sure :thumb2:
                • spanner570
                  • 15403
                  #23
                  .........good grief!
                  • Peter Gillson
                    • 2594
                    #24
                    Hi Tim - great explanation of the role of cavalry.
                    As you say there were two tactics, it was the Royalists under Prince Rupert which first used the 'gallopers' tactics while the Parliamentarians tended to use the 6 rank tactic of the 'trotters', at least at the start of the war. As they came to understand the Royalist tactics they did start to adopt them.
                    since the cavalry on both sides tended to be situated on the flanks their first objective was to destroy or reduce the effectiveness of the opposition cavalry, thereafter being able to consider the opposition infantry, especially if they could outflank infantry which had not fully 'squared'. At the battle of Marston Moor, Cromwell defeated the Royalist cavalry before turning on their infantry. Then amazingly he then crossed the battlefield to assist the cavalry on the other flank.
                    i think it is probably a case of cavalry v cavalry was planned, while cavalry v infantry was opportunistic.
                    Peter
                      • 18907
                      Peter
                      Cheers Peter. Yep, tactics were certainly in flux around that time. Marston moor was a bit of an outlier though wasnโ€™t it. Edgehill was more commonโ€ฆโ€ฆespecially for gallopers. The cavalry charge, get overexcited, then canโ€™t be recalled or reformed. This made them a bit of a one shot weapon. Happened to the Greys at Waterloo as well. Due to the adrenaline of the charge getting them wound up I suppose.
                      • Steve-the-Duck
                        • Jul 2020
                        • 1731
                        • Chris
                        • Medway Towns
                        #26
                        Now, there's some well-read background stuff from Tim.
                        Isn't it interesting that cavalry are supposed to receive a 'charge' static, yet one of the reasons stated for the destruction of one of the cuirassier units was they were unable to manoeuvre to receive a charge against them. Is that hindsight analysis? Can't remember if that was the 'lobsters' or the other regiment
                        For info purposes, cuirassiers of the pike and shotte period wore full armour, everywhere but the back of the legs just about, unlike say Napoleonic cuirassiers with 'just' breast and backplate and helmet
                        That's what I like about this forum is all the xtra info shared
                        • Peter Gillson
                          • 2594
                          #27
                          Agreed. Always more to learn.
                          • Peter Gillson
                            • 2594
                            #28
                            One thing with these major conversions is the time it takes for the putty to cure, so it makes sense to work on more than one horse at a time. Yesterday I started on one of the galloping horse, one with virtually no convirsion work to it - other than detailing.
                            One of the great advantages of using Historex horses for conversion is that the type of plastic is a softish type of hard plastic, which is easier to cut and carve that the type used by other manufacturers such as Airfix. This does have a down side - I have had horses snap at the ancle, so some surgery is needed, even on a horse which is otherwise 'out of the box:
                            firstly a channal is cut in the inside of one of the legs which touched the ground:
                            then a paperclip is threaded into place, and glued;
                            Finally putty is used to securle the wire in place and to rebuild the musculature of the leg:
                            now I have a horse half which can take any amount of weight and manhandling without any risk of snapping.
                            Peter
                            • scottie3158
                              • 14201
                              • Holbeach
                              #29
                              Peter,
                              I'm in mate. I wish I had your confidence to cut and shut the figures the way you do.
                              • Peter Gillson
                                • 2594
                                #30
                                Peter,
                                It's nice that Historex sell the horse parts individually so you don't have to buy a whole kit so the loss of messing up is not as bad as it could be. It is also surprising what filler can hide.
                                for me a key is not to rush. For instance filling over the paperclip took 2 evenings: the first was to roughly fill the channel Let the putty cure overnight, then add the surface musculature. Taking it one step at a time takes time which is why i work on more than one horse at a time - more time is spent waiting for the putty to cure than actually applying the putty.
                                Peter
