Une Ferme Abandonnee.....and some squatters! Normandy, July 1944
Thanks chaps. It's really nice to read such encouraging posts. :thumb2:
Farmhouse glued together and windows fitted. I use thin plastic card for the windows. Marked out with a pencil and carefully cut out using a N0 11 scalpel blade. I 'glazed' them with bit of see through plastic food container lids.
Oops! Bit of a wonky upstairs window. I know I want a rustic look, but really........
I still need to sharpen up some of the half timbering. That will come later.
Ian. Pity Miniart don't do 1/72. I'm sure they get enough 'Samples' from would be fortune hunters without this toe rag sending stuff.
Dave. A Book?! I read out your post to the missus. "Fat chance, You can't even get a shopping list right!" was her encouraging reply.
Apart from anything else, and presuming my stuff was remotely good enough, the tongue in cheek sort of thing you and Ian suggest is not my bag. I prefer to quietly sit at the back and dish out the pencils!...and just have fun and pootle along in my own sweet way. :upside:
Update.....
I've started on the chimblee for the 'ouse.
Whether internal, external , brick or stone, the bond has to be summat like running true. It's imperative to give this part your best shot. Any straight, vertical lines are to be avoided. They just don't look right and can spoil the corners of the structure.
Here I've marked out the brickwork onto the foam board. Luckily I don't require bricks all the way down.
Cut into strips and ready to glue.
All the bricks bond around the corners. Just what I wanted.
To finish off, dig your finger nail into the corner edges of the 'mortar joint' This breaks up the sharp edges of the stack.
Done. All that is needed to finish the stack is a capping and a couple of pots.
[ATTACH=CONFIG]n1215205[/ATTACH]
[ATTACH=CONFIG]n1215206[/ATTACH]
[ATTACH=CONFIG]n1215207[/ATTACH]
[ATTACH=CONFIG]n1215208[/ATTACH]
Cheers.
Ron
With such a ringing endorsement, what's keeping you? Get on with it! :smiling:
