Une Ferme Abandonnee.....and some squatters! Normandy, July 1944
  • Gern
    • 9212
    #106
    Silly question, but 'ow is Monsieur Farmer supposed to get into 'is pigeonnier?
    • spanner570
      • 15384
      #107
      Hi 'Big Box'!
      When the farmer first made the thing, there were proper steps going up into it, but folks kept going up there and having all sorts of shenanigans when he was in the fields.
      So he removed the steps and now uses a ladder to access the structure. There is a trap door accessible from the entrance to the courtyard. This can't be seen in the above image.....
      Otherwise you wouldn't ask such a daft question!:tongue-out3:
      Ron 21- Dave 0
      • Gern
        • 9212
        #108
        So whoever said "There's no such thing as a stupid question" was wrong! Clearly there are or Ron wouldn't be 21 points in front! :sad:
        • spanner570
          • 15384
          #109
          Brilliant riposte, Dave!
          Ron 21- Dave 1
          • Gern
            • 9212
            #110
            Oooohhh! Catching up! Now, what are the chances of me not asking any more stupid questions?
            • spanner570
              • 15384
              #111
              Fat chance!
              Update....
              Apart from a bit of detailing, the roofing is almost finished.
ID:	1216204Click image for larger version
ID:	1216205Click image for larger version
              I'm sure that gunfire is getting closer.......
              Cheers.
              Ron
                • 15669
                That's looking excellent Ron.
                • spanner570
                  • 15384
                  #113
                  Thanks Jim. Always nice to have your feedback on my stuff. :thumb2:
                  I've turned my attention back to the Pigeon 'ase.
                  I marked and cut the thing in two. removed the centre section and the top bit up to the roof join.
                  Then I stuck it all back together......
                  The present Mrs. Ron approves, so that's good enough for me!
                  Cheers.
                  Ron
                  • JR
                    • May 2015
                    • 18273
                    #114
                    570, damned good stuff, love the banter between you and Dave.
                    Watching and taking notes.
                    453.
                    • scottie3158
                      • 14201
                      • Holbeach
                      #115
                      Ron,
                      Cooooooo that's good.
                      • minitnkr
                        Charter Rabble member
                        • 7520
                        • Dayton, OH USA
                        #116
                        Agree w/Missus, looks very good now.
                          • 15669
                          Definitely better.
                          • spanner570
                            • 15384
                            #118
                            Thanks chaps.
                            Doesn't it annoy you when the wife is right? Mind you, I should be used to it by now, because she always is!
                            Update.
                            One water wheel recipe....
                            Imagination.
                            Pencil
                            Plastic card
                            A bit of sprue
                            Four bits of summat plastic for the spacers
                            Polystyrene glue
                            Kiddies paint
                            Scalpel
                            Patience
                            Mark out yer wheel on to the card. Don't be too fussy about getting the segments all the same. I'm not.
                            Using a scalpel, cut out the wheel
                            I filed down the spokes a bit on the first and used it as a template to make the second one.
                            The second one....
                            Testing, testing.
                            Add spacers. It's up to you how you do this. This is my fourth wheel and every one is different.
                            You can just make out the wood grain. Use your scalpel or sandpaper to scratch the surface, then paint.
                            Roughly painted
                            The two halves glued to the spacers
                            Paddles cut from thin plastic card. It's up to you how many. I eventually cut 24 for this one.
                            Paddles stuck on with polystyrene glue.
                            Axle made from a bit of sprue.
                            All painted up.
                            Job done....
                            Just noticed, one paddle has thrown a wobbler!
                            Next up I'll set to thinking about the mill race, fish steps and the stream in general.
                            Cheers.
                            Ron
                            • minitnkr
                              • 7520
                              • Dayton, OH USA
                              #119
                              ....and so it goes. Great work.
                              • spanner570
                                • 15384
                                #120
                                Thanks Paul.
                                Slowly getting there. Mind you, just what 'there' is, I haven't a clue! :upside:
