Une Ferme Abandonnee.....and some squatters! Normandy, July 1944
    • 15641
    That's wheelie good Ron. :rolling:
    • Andy T
      • Apr 2021
      • 3239
      #122
      Just like that!
      Looks so good I could imagine it working.
      • flyjoe180
        • Jan 2012
        • 12367
        • Joe
        • Earth
        #123
        Great work all round, Ron. That paddle wheel is simply brilliant
        • spanner570
          • 15377
          #124
          Thanks boys. I'm chuffed you like me weel!
          Time to try and create summat for it to sit in.....
          Thanks again.
          Ron
          • Steven000
            • Aug 2018
            • 2822
            • Steven
            • Belgium
            #125
            Nice progress Ron, all looking good :thumb2: cheers
            • Mini Me
              • Jun 2018
              • 10711
              #126
              Looks like yer on a "roll" 570.......keep it coming Sir! :thumb2:
              • JR
                • May 2015
                • 18273
                #127
                Great photos showing the method 570, just proves you don't need to spent to be able to produce something as realistic as that.
                Hat doffed.
                453
                • Graeme C.
                  • 1597
                  • Graeme
                  • UK
                  #128
                  Nicely distressed looking Ron, I'd leave the out of place paddle, it fits with the rest of the building.
                  • spanner570
                    • 15377
                    #129
                    A very belated thanks boys! Sorry for the delay in responding.
                    I now find I need to push this build to a conclusion so on we go at a rather obscene pace......
                    I had hoped to confine the whole model to A4 size, but I've just run out of room, so radical alterations are in order.
                    This was the original layout. See the edge of the A4 foam board base.
                    I've added some half timbering and brickwork to the gable of the stable block and made me a diddy wall.
                    Next, to compact the model as much as possible, I've had to spin the mill around thru 90 degrees. This will allow me a bit of wiggle room for the stream. I've still had to add a small strip to the base to give me a bit of a steam down the back side of the mill.
                    I've also mounted the whole thing on a piece of 4mm plywood and started to build up the banks of the stream and the fish ladders using scrap bits of polystyrene.
                    The wheel is just loose fitted for now.
                    Cheers.
                    Ron
                    • spanner570
                      • 15377
                      #130
                      A couple of days ago my wife informed me the model needs a bridge. More to the point she wanted one!
                      Her observation was quite right. A watercourse, no matter how small and knackered, has to have a bridge, doesn't it?
                      Now't fancy, I've made it from off cuts of foam board and a couple of pieces of cereal packet. Suitably scribed and painted with cheapo acrylics.
                      One side....
                      The 'Kelloggs' road. Other cereal packets are available.
                      T'other side....
                      I made a booboo when designing the bridge. :upside:
                      The bridge is square on with the buildings and courtyard. I made the two sides of the bridge opposite hand, but identical, if yer folla. I forgot to take into account the stream runs at an angle to the bridge, so I've ended up with the arch slightly on the scunt. No big deal, but a pain to cut the Kelloggs to fit the cob shape of the arch.
                      Loosely in situ.
                      Cheers.
                      Ron
                      • scottie3158
                        • 14197
                        • Holbeach
                        #131
                        Where would you be without her indoors keeping you on the straight and narrow. Cracking work with the bridge.
                          • 18882
                          Skew arch bridge looks good Ron. That’s how they built ‘em, arch in line with the roadway for strength :thumb2:
                          • Mini Me
                            • Jun 2018
                            • 10711
                            #133
                            ....more like wheatabix way 570.
                            • spanner570
                              • 15377
                              #134
                              Thanks chaps.
                              One hour ago, my dear wife looked over my shoulder at the model and said "... ....... .... .......!" Sort of.
                              More to follow
                              • Gern
                                • 9209
                                #135
                                Thanks chaps.
                                More to follow
                                Strange. On the couple of occasions I met Justine at Cosford she was always polite and very articulate. I can't imagine her resorting to such foul language!
