RT-Diorama 1/35 12-Ton Harbor Crane
  • Andy the Sheep
    • Apr 2019
    • 1864
    • Andrea
    • North Eastern Italy
    #16
    I'm in, Graf Allen von Bamberg
    Had a look at the RT on-line shop and it's amazing . Didn't know of its existence. Thank you for the hint.
    • colin m
      • 8755
      • Colin
      • Stafford, UK
      #17
      A weatherer's dream. (I think I made a new word up there) Lots of scope for rust etc.
      • JR
        • May 2015
        • 18273
        #18
        Is'it just , and a great word .
        • colin m
          • 8755
          • Colin
          • Stafford, UK
          #19
          Thank you kindly Mr race. I think that word might find a place in 'Colin's' dictionary, as opposed to the normal 'Collins' dictionary.
          • Allen Dewire
            • 4741
            • Allen
            • Bamberg
            #20
            Evening from the Wood Work 101's table,
            Originally posted by papa 695
            Just pulled up my chair for this one Allen.
            Welcome Ian! Get comfy and glad to have you here...
            Originally posted by Waspie
            Well Allen, a dockyard crane. This has to worth a ride on the Magic Carpet Mk 7 to watch. :thumb2: :smiling2:
            I hope so Doug. Just don't forget to wear your winter woolies while flying over here. It's getting colder outside now...
            Your welcome Andrea! Now that you are retired, you have some time to try a kit from them. It could be damaging to the wallet, but hey, it's Christmas time and I'm sure you have been a good boy!!!...
            More like a weather's nightmare Colin!!! I'm not to good at that art yet...
            Easy Killa!!!...
            I'm sure it could find a place. It ain't in my Funk & Wagnall's yet......But 'nightmare' is.......
            I got too involved with playing and forgot to post last night, so here's what I have done so far. I did glue the Traction Machine house together,
            The Wolverine PVA works well, but is a bit thick and starts to dry on contact with the parts. You gotta work quickly. Then I started cutting out more parts,
            I started to play with the white squares and the 2 wheels and ended up making this,
            After 20 minutes of jiggling around, I finally got the top piece on and found I had created a water wheel,
            Here I was thinking I was building a crane and not a paddle wheel floaty thing. Actually, it's the bottom plate of the crane' turntable. You add two white pieces and you have this,
            Letting this dry, I assembled the operator's cab frame. Real easy and used a 4 little clamps to hold it together till the PVA set,
            Perfect fit! The parts are well laser cut and fun to assemble.....So far. The other parts I had removed earlier were for the trim and vents on the Traction Machine. They look like this,
            Here it is sitting in place in the cab,
            I just need to add the wheels to it and some paint. Too bad you won't see much of it when the wood sidings are added to the frame. I guess I'll have to leave the door open so you get a peek inside. I then went about removing the 3D parts I needed from their plate. My gawd!!!...There were about 20,000 supports to try and cut off. It took well over an hour to get these free,
            Luckily, I didn't break anything and they still needed clean up. The detail is excellent on these. look at the door handles and notice the keyhole in the plate. I then noticed the U-shaped hooks were not well printed and useless. No big deal. Also note the door hinges I need to cut off too. That's as far as I got last night, so today, I spent a lot of time cleaning the nubs off the 3D pieces and cutting out more wood. I did a test fit of the main boom parts,
            Again, it has a nice fit, but will be a little tricky to glue together. The maintenance ladder is a nice touch too. The pieces below the boom are for the cable rollers and add extra support to the boom. Another pic,
            A view of the etched in details and the ladder. I guess Rudy had to climb up in the boom to oil the rollers and grease the cables once a month. He probably wasn't amused..................
            That's it for this installment of Wood Working 101. Thank you for the comments and for looking in. Have a good one take care folks...
            Allen
            • JR
              • May 2015
              • 18273
              #21
              That looks a fine kit Dude1.
              Remember mdf can swell when you attempt to paint with any water based paint. Try a damp cloth on an underside first to raise the surface, it may cause a little wooliness. Do they mention anything about painting in the box ?
