Last update for a few days as I have to go away due to family circumstances.
Engine intakes have been assembled and the ramp has had its retraction mechanism attached.
Looking further forward to mounting the dropship on the diorama base I realised I need to add a counterweight as the rod that will support the dropship will enter the main body behind the APC bay and in front of the rear landing leg. This point is quite a distance behind the current centre of gravity, so the counterweight is needed to fix that. So I used some of the lead shot I bought a few weeks ago for the Hawker Hunter model
Then attention moved to the base itself. Since my idea is to capture the landing and dust off moment, I'mm have a piece of the landing pad and a bit of the landscape. As usual, my supply of old cheap picture frames comes in handy and along with the trusty claycrete, balsa wood formers for the rocks, some plastic strip for the landing pad foundation and we have this
On top of the landing pad foundation, I'll use some of my old reliable metal mesh from the Meccano spares box:
So now its just a matter of waiting for the claycrete to dry, which is likely to take several days now. That leave time for the acrylic rod and brass tube to arrive that will be used to create the stand. I forgot to order these before. I'm using 8mm clear acrylic rod and inside the dropship I'll have a length of 9mm brass tube for it to slot into. This will be sealed inside the body using araldite to give it a good strong support since the dropship does weight a not inconsequential amount!
